Galaxian repair log (final part)
sukhbir
45 (100%)
1,613CR
Ok now i removed the 2x vrams(2114) from location 3F and 3H and tested them in my pacman board and 1 failed and other one was ok. gx-9.jpg
fitted two new srams and powered up...............................................gx-7.jpggx-8.jpg
Well what can i say o_O,good news is the game runs and plays but as you can see all sprites and tile graphics are a mess.
This fault had to be in the sprite and tile circuit ,i suspected possibly bad sprite and tile roms,so these are located at 1L and 1J,
i dumped these and they romident ok.Had a hunch it may be a addressing issue so i started scoping all the 74ls157 in the sprite/tile circuit and i came across a 74ls157 at 6J,pin 7 output was stuck high.gx-16.jpg
replaced with a new ls157 powered on and.............................................gx-13.jpggx-14.jpg
Ooooo yes :cool:,galaxians live again!
put in a credit and played it with no issues except the fire sound was missing and also the explosion sound when you get destroyed.
from the schematic there is a bilateral quad chip at 7T,there was no output from pin 3 and 10 .
replaced with a new one and all sounds were back,soak tested the game for 2 hours and all was well.
50 (98%)
1,821CR
Nice fix. I had a similar sound issue on a Pacman board, just like yours it was also a faulty 4066 Quad Bilateral switch.
sukhbir
45 (100%)
1,613CR
Thanks :)(y),those 4066 chips are also present in scramble and super cobra boards which I’ve had to replace due to sound effect issues,I bought a bundle of them to keep in stock.
