Alca Space Firebird U/R ( ex Duke Of Lancaster ship)
Ronnie Dent
1,155CR
Well! I have been looking for an upright version of this game in what seems like forever! Having owned the table version for many years and to be fair that's the version I played back in the day in the pubs. I only ever seen and played an upright once in an Arcade and it was the Alca version.
So I have found one externally intact but raped inside! the good news is I have A boardset for it and one of those nos 17" monitors, annoyingly I recently sold 2 19" monitors!
Screenshot 2026-04-19 at 08-33-47 Space Firebird - Multigame Retro Arcade Machine. Fully Worki...png
so the internals look like this
Screenshot 2026-04-19 at 08-17-18 Space Firebird - Multigame Retro Arcade Machine. Fully Worki...png
A blank canvas almost! I found a picture in a thread on here that showed the internals, this gives me an idea of how it should be. Need to figure out in the boards are on a metal plate or wood.
I'm missing the credit board, power brick and psu, but I do have these spare from a cocktail table that I may have to use. If anyone owns one of these and can take picks that would be a great help? Even better if anyone has any of the parts I'm missing to restore it?
How it should look
Thanks Ronnie
Ronnie Dent
1,155CR
I guess not many of these about, was hoping someone has or had a cab that might have some images, or even a similar styled Alca cab
Found this price list, looks like as well as an upright there was a compact cab too
Lukey13
119CR
I've got an Alca cab but Im missing my bottom door :(
Is your bottom door original with those carriage bolts?... And if so could you possibly post some pics so I can attempt to reproduce it please?..
Was going to make something out of wood but tbh would probably prefer to make it from metal!
P.S. I absolutely love the woodgrain shade on these! :cool:
Ronnie Dent
1,155CR
Here are some pics of the coin door, it is wood with a stainless steel facing bent round sides and top, hope these help. Would be nice to see some pics of your cab inside and out ?
Lukey13
119CR
Nice one thanks a lot, appreciate that!
I’ve got an ALCA Planet.. it’s a vector, and from what I’ve found out it’s more like an Asteroids deluxe gameplay wise.
The board boots up and I can play a game blind as I have sound but just get nothing on the monitor.
I’ll try and find some pics 👍
jengineer
47 (100%)
1,178CR
yes it's a really nice machine this Ronnie, it's a shame it was stripped by someone
just to make everyone aware I did try and sell this for a friend of mine a couple of months ago which is why it was pictured in my unit - but I am confirming it was not stripped & converted by me,
the first time I ever saw this was on 5th march 26 when I helped remove it from the site VideOdyssey and I did no conversion work to it what-so-ever,
such a shame it was stripped of the original parts,
5,648CR
Looks great. Did you try Novus 321 on the fag burns? It's worked great for me in the past. Won't get rid completely, but much improved. Then again, I don't mind a few battle scars on cabs these days. Gives them a bit of unique character. 🙂
Ronnie Dent
1,155CR
Thanks, I used wet and dry started with 400 grit working upto 2500grit then used a DA polisher with compound to finish, Novus is great but this needed major intervention!
Ronnie Dent
1,155CR
Front pic of machine with control panel temp fitted, the marquee was removed along with led strips and replaced with a flo tube and choke, also car. Speaker and grill replaced with an arcade speaker .
The coach bolts in the cash box door were far too big! I replaced with smaller M5 bolts on the top 2, bottom 2 are longer so had to order some, you will see the difference in the pics
Still loads to do, cab need rewired for space firebird, need to cut a board to mount the boards
Not decided to use a switcher or linear psu, I have both available to
Use. Also need to refresh the black paint and fill the screw holes that will not be used
Ronnie Dent
1,155CR
Looking at the internals from the reference machine which is the same machine, the psu looks to have been changed at some point going by the choc block connectors! also the edge connector on the left looks to be the same now as was in the below pic, So I might just rewire that and leave where it is and make up a finger board to suit the firebird boardset, The dilema is do I use a Nintendo boardset with all those little connector plugs (looks like it did have one fitted?) or do I use a bootleg set with edge connector? I have both I could use, decisions!
Looking at the pic again the edge connector looks to be a small pcb no idea what that might be, maybe a video inverter for the weird sync these boards have? Ideas welcome?
