Right it still sounds like either a power issue or a short somewhere.
If you have tested the triacs and transistors and resisters out of
circuit and they are fine then I would look at making sure that the
voltages are fine.
With J115 off, go to test menu and make sure general adjust 25 Illumantation Dim is On. If this is off the GI will not dim.
Have you confirmed with J115 disconnected that you are getting about 6 to 7 VAC from the connector (Pin 3 and 12 will do)
Check the voltages on the board with J115 disconnected and the board on. What voltages are the TPs reading? If they seem too high or too low then test each side of J101 to make sure you are gettting 12 to 14VAC and 8.5 to 9.5VAC.
Check to make sure that BR1 and BR2 do not have any dry joints.
Check that U1 74LS374 is working as this is what drives the triacs. If this is faulty it could be shorting something. Pins 2, 19, 5, 16, 6 are the outputs and these should be on when the GI is on.
Whilst you are there replace caps C9, C4, C1, C12, C2 and C3 just to make sure the digital 5V and 12V have nice clean power.
GameOn2016-11-20 16:43:42
