First time applying side art.
antray84
559CR
I have been in the hobby for 7 years now but have always avoided side art application as it was the kryptonite to my OCD. But in restoring a Nintendo Cabinet to a VS system I was left with little choice.
It didn't come out perfect (it never does) but I am happy with the results and it was a lot less daunting then I had prepared my self for. My advice is to prepare prepare prepare. As fail to prepare and prepare to fail. PXL_20250323_134545054.jpgPXL_20250323_162305449.MP.jpgPXL_20250323_162313677.jpg
channel27
1,290CR
What’s the technique? Ive seen it done with water spray and a squeegee so it can be moved around before it’s flattened out? Or do
You just line it up and go for it?
My HotD and SF2 cabs both needs side art but I’m scared 🤣
antray84
559CR
I went with the line it up and go for it. I came to the conclusion that I would be disappointed no matter what and went with the pessimistic approach. As I said, lining it up before hand and preparing everything made it easier. Free-handing it or hoping for the best is never a good call. My cab was also not completely flat so the whole thing has a texture to it. This made it easier as you don't notice the tiny impections as they blend into the textured finish.
Only issues I had was erasing the pencil I used to line up everything. Has left some light marks and the art creasing ever so slightly around the bolt holes. But that is a Nintendo cab only issue.
I won't lie I am glad it is over as if you mess it up it would be super annoying.
Mikonos11
89CR
In case you ever find yourself in the same situation, or so it might be helpful to someone else, here's my little tutorial to explain to my fans how to properly glue. I'll explain a few things that haven't been mentioned or seen in tutorials or video-tutorials.
How to stick small-medium sized vinyls (By Mikonos):
1.- Clean the surface where the vinyls will go well.
2.- Prepare a solution of water and soap in a bottle with a spray applicator, preferably.
3.- Clean your hands well with soap to handle the vinyl.
4.- Wet the surface, your hands and the vinyl on the adhesive side with water and soap. Follow this order. At this point, you will be able to touch the vinyl on the adhesive side without any problem.
5.- Place the sticker on the surface without applying force, moving it gently until it is in its final position.
6.- Apply force with a plastic card or a vinyl applicator to carefully remove the water between the vinyl and the surface. Apply force from the center of the vinyl outwards.
7.- If you don't have much experience, it will be normal for water bubbles to remain between the vinyl and the surface. Don't worry, it's just a matter of a few weeks before the water evaporates completely and the vinyl looks perfect.
NOTE 1: You don't need transfer paper, especially if it's not transparent and because there are no loose vinyls that need to be kept at certain distances from each other. You'll do a much more precise work handling small or medium vinyls this way, especially when positioning them.
NOTE 2: With vinyls with transparent parts, you should use soap and water to avoid the risk of matte areas or defects.
Cheers!
