Frogger Freeplay / High Score Save
philmurr
46 (100%)
2,333CR
So I included Frogger in my Konami/Stern multigame around 6 years ago but never did a standalone freeplay / high score save kit. Until now. Most of the code was already done but it did need adapting to work on a Frogger pcb (with its different memory map), and with my high score save board.
Uses my Z80 single ROM/high score save board like the rest of my mods, and adds a few features:-
- Freeplay maintaining attract mode (select using "1 coin 2 plays" coinage DIPs), and just press P1 or P2 start to begin a game
- Saves high scores to serial EEPROM
- Has 2 "versions" of Frogger, the original and the bugfixed (https://forums.arcade-museum.com/threads/frogger-bugs-descriptions-and-fixes.482765/). Choose by moving joystick right or left at power-up which one you want to run (or it remembers your selection from last time)
- Separate high score tables for original and bugfixed versions. You can reset each high score table individually by holding joystick up on power-up
Photos show attract mode running with freeplay, the 2 separate high score tables for original and bugfixed versions (eagle-eyed will notice HI-SCORE and IH-SCORE, that was just for me when I was testing so I could easily see which version is currently running, it has been changed for the final version of code!), and the kit installed on a Sega/Gremlin Frogger pcb.
Frogger HSS demo 0923.jpg Frogger HSS HST1 0923.jpg Frogger HSS HST2 0923.jpg Frogger HSS PCB 0923.jpg
lewinskys
14CR
View attachment 13416 View attachment 13417 View attachment 13418 View attachment 13419
Where does one get this unit? Download info? or Purchase?
