Problem Galaxian upright cab
Volt
1CR
Did it work before now?
Has it ever worked?
Did you see it working before you bought it?
Hi yes it worked when we first had it then somtimes when turned on it wouldnt work no sound or video and other times it would come on now when turned on it plays with sound no video.
Mr20to5
1,362CR
Are you able to check (carefully) if the monitor is getting fed the voltages it needs from the psu?
As Lurch says, it is likely one or the other, first step is to work out which.
Not knowing what your skill levels are, please do NOT go poking around the monitor, even switched off, if you don't know what you are doing.
Volt
1CR
Ive got no skills with arcade machines but i do know that those old monitors hold thousands of volts even when unplugged i was hopping someone who lived near me might come round and maybe fix it .
PAC-MAN
441CR
No need to be frightened of it, as long as you take your time and don't put the end of your nose near the Anode Cap you'll be just fine.
Where are you located?
* Edit, I see you're from Leicester, too far for me *
grobda
1,061CR
a 5 quid multimeter will at least let you see if its not just a loose wire or a blown fuse.
there's a video here where a guy does some basics.
Mr20to5
1,362CR
@Volt it can be daunting, at first, but with owning a 40+ year old cab, it's going to fail, probably more than once, and it's a great feeling when you find the fault and fix it, yourself.
There are tons of folk on here that will help you do just that, and keep you away from the scary voltages whilst doing so.
Start by putting up some decent photos of the internals, so we can see what you have. Is it all original, some parts replaced etc, and we'll go from there.
If you don't have a multi meter, now is the time to spend a tenner and buy one.
Volt
1CR
Ok thanks ,its original it was found in the basment of a pub in norfolk and the bloke plugged it in and it worked i transported it back of van on its back back home it worked perfect for about 5 weeks then on and off
big10p
Coins detected in pocket!
5,645CR
If it's been stored in a cellar for years, it's a good idea to give everything a good look over and service. Check fuses on the power board at the bottom. The monitor fuse should be bottom left, under the grey cardboard cover. Disconnect the game PCB and check the connections for signs of heat damage.
Volt
1CR
Ive had it at home for 10 years
Ive checked fuses they are on the floor of the machine and are ok
