Help needed with consoles to Ikegami monitor
frothmeister
58 (100%)
927CR
Hi guys,
Asking this for a friend who has an Ikegami TM20-20RP broadcast monitor.
He hasn't used it yet, but wants to connect up some retro consoles -
Sega Saturn, Original XBox, Playstation etc. He connects all of these to TV's via SCART at the moment.
He's asked me what cables he needs, but I'm not sure either.
Is it BNC to SCART ones? If so, can anyone recommend exactly which type to get and a reliable seller.
jinq-sea
237CR
That looks like Sync on Green, so I'm not sure where you'd get the correct BNC adapter. The ones from Retro Gaming Cables are R/G/B/Sync.
grobda
1,061CR
Initially I used some phono to bnc adaptors (https://uk.farnell.com/pro-signal/secon14/adaptor-phono-skt-bnc-plug/dp/3706722?) and various rgb or component out cables (as you'd hook up consoles to some older LCD/Plasma TV's) The RGB sync is separate - it's in the video input section to the right of the RGB/Component inputs.
you can get some pre-made cables. e.g. this https://www.amazon.co.uk/dp/B0050HNJW4/ ive used component out and RGB out from my PS/2, and component out from an original xbox.
As I have scart cables for most of my RGB-capable consoles eventually I just wired a scart socket to the back of it. Can still use composite for sh*tty things that don't have native RGB.
grobda2019-02-14 18:52:54
mr_ppp
26CR
I've got the same monitor for my retro consoles, in fact I have two
I tend to use a sync strike combined with a vga to bnc cable, works like a champ on everything so far, add in a decent scart switcher to save having to unplug each cable and your set
As Grobda states, the extra sync connector is hooked up to the appropriate connector to the right, also make sure external sync is enabled on the Ikegami front panel
http://arcadeforge.net/Scaler-and-Strike-Devices/Sync-Strike::15.html
https://www.ebay.co.uk/itm/VGA-Monitor-Male-15-pin-to-5-BNC-Audio-Video-Cable/264195304519?hash=item3d83446c47:g:ylkAAOSwMpFcUfQI:rk:2:pf:1&frcectupt=true
There may be cheaper options but this has worked for me on everything I've tested so far, also meant I could keep my old console cables (at least the rgb ones)
I acquired the service manual for this monitor a few years back from Ikegami UK, if wanted heres a link you can grab it from on my Google drive
https://drive.google.com/file/d/0B2wro3G-6SYpQklnY0t4bEJyanM/view?usp=sharing
mr_ppp2019-02-15 02:37:46
frothmeister
58 (100%)
927CR
Many thanks for the help guys and thanks for that manual link Phil
. I have just downloaded for my mate.
So, the syncstrike thing looks pretty good, but ideally he's not looking to pay as much as that would cost, especially after importing. Anyone got a cheaper solution?
