Problem intermittent Shaky graphics - Atari Battle Zone Cabaret
b1ffb0ff
26CR
Just replaced the controllers, not been switched on in a while. Had a quick blast and every once in a while the screen shudders.
There is a video here of the issue: -
Any thoughts please?
John
Fantazia2
2,209CR
Is it still running the RedZone multiboard? If so does it do it on all the games and the system menus? Theres a monitor test as well but no idea what this gives you.
There are pots to adjust X and Y size and position, does adjusting these make any difference to the issues.
Other than that can only suggested checking the edge connectors are clean, and then point fingers at the monitor.
b1ffb0ff
26CR
hi buddy, yes running redzone board. not checked all games will check - assumed monitor issue TBH - i can try the pots - i guess was hoping someone would recognise the symptoms and push me right to the area on the Defection board :)
