Something weird has happended to my MAMEWAH set up on my MAME cab.
It all boots up fine but when I try to run any game from one of the menus, it won't load/run - nothing happens when I press 1 button (which have checked works fine on the keyboard) and otherwise within MAMEWAH to navigate the menus. MAMEWAH otherwise seems fine ie can move between menus etc.
I've not done anything that I'm aware of to change the set up at all. AlL I did last time it worked 9day before) was play a game of Mad Planets and change the inputs for the left and right spin to see if I could get it playable without a spinner (answer was no!) but can't see why or how this could affect MAMEWAH running games.
I didn't do the orignal set up so not sure of the paths so wondering if somehow the ROM path has been moved but can't find where this would be in the set up.
I've attached a zip of the MAMEWAH folder on the MAME PC if anyone wants to look to see what might be wrong?
Thanks in advance for any help.
Greg
PS I have Wolfmame on the PC too and can run Mad Planets for example through the command prompt so MAME will work but be nice to be able to use the menus to navigate to games more easily and see suggestions from my custom lists whch took ages to create.
Greg
