Mini PC for Light Gun Games
Coops
56CR
Hey,
I was scrolling through Facebook and I saw an advert come up for a retrogaming website that sold mini pc's that you could play light gun games on your modern TV using the Sinden Light Gun.
I don't know much about this stuff, so how easy is it to set up one of those Mini PCs for light gun games yourself without spending a fortune on the pre-installed ones? I know the Sinden Light Gun is about £90.
I have also seen the G'Aim'E light gun unit as I really enjoyed playing Point Blank when I was younger but they only come with a few games installed.
Brettster
20 (100%)
1,232CR
I have the Gaime thing, with the 4 games, it didnt work welll at first, then they released an update which fixed most of the issues, but I still have an issue with my TV being too big for the room, I really should sell it on! lol but if you have a smaller TV or larger room, then its a cheaper way to get into it. but only 4 games so far
Venom
720CR
lot more builds like coinops with light gun games now. i have a very reflective lg oled so not sure sinden will be good or not. i stick with dolphin bar for stuff like rambo on teknoparrot ! Old Skool !!
2huwman
349CR
I need to try my Gaime again if they've updated it as I had the same issue with the TV being borderline too big for the space. I also read something (haven't tried it yet) that said that if you train it on your TV, and then plug a PC into the same TV, you can use the gun with MAME and Tecknoparrot etc and it will be properly calibrated. Guess it saves the info in the gun rather than the box.
Gun4IR also worked really well but was a bit of a messy hassle with the IR emitters stuck around the TV. They also got really hot and I started worrying about getting eye damage! Don't think that's physically possible unless you're very close to the emitters, but it put me off anyway.
Having tried lots of non CRT based systems, I honestly found the Ultimarc guns perfectly playable and easy to set up, especially with the newer arcade games on Tecknoparrot, and not significantly worse than other IR or camera solutions. Two linked PS2s with Time Crisis 2 and a pair of GunCons and Trinitrons is hard to beat though!
ZedEx48K
8-Bit
1,377CR
Eeeeeew :D I had some once, they were terrible, they work the same as a wiimote so accuracy wasn't great and should you dare to move from where you were sat you had to calibrate again!
IR emitters will get warm in use, but first I've ever heard of someone think of eye damage!
2huwman
349CR
Yeah you can definitely damage your retinas with IR emitters. As I said, you need to be close for that to happen, so at normal play distance there's no real risk.
I know a lot of people don't like the Ultimarc guns, and they're definitely inferior to Gun4IR, but I found with standing at a bit of a distance, with careful calibration, and then not moving from that position, they were perfectly fine for the newer Teknoparrot stuff like the Transformers games etc. Older stuff I'd generally play on cabs or CRTs.
Chihiro
799CR
HOTD4 plays good on the mouse.
Naomi games running on a Pi5 via Batocera such as HOTD2, Maze of Kings & Confidential Mission are ok on a analogue pad too.
Both options are good if you don't have a gun setup
4,697CR
Sound worse than I imagined them, after playing Mad Dog on Philips CDi and the mouse Gun delay I thought no way I'm buying that type
ZedEx48K
8-Bit
1,377CR
That was for Aimtraks, I have g4ir and they are great, not quite CRT great, but as close as we are getting so far, though in practice you would never really know with most arcade games.
