I'm building a repro monkey ball control panel and just need to finish the wiring looms to complete it.
I have completed the 2 spade to 12 pin AMP UP for the start button and a 4 pin JST to 26 pin I/O connector for the Op Amp to IO.
So i just need to connect the joystick to a 6 pin JST which plugs into the IO. Question is 'Where do the relevant wires connect on the two analogue pots of the joystick?' I think they're technically referred to as 'volume' pots
I have the 6 pin JST wired as below:
Pin 1 YELLOW - I believe this is Vertical
Pin 2 YELLOW - I believe this is Vertical
Pin 3 RED - I believe this is Horizontal
Pin 4 BLUE - I believe this is Horizontal
Pin 5 WHITE - Ground
Pin 6 WHITE - Ground
Anyone know where each wire connects to the analogue 'volume' pots?
