Nice little psu ?
8,051CR
Picked up this nice little psu
ASUs usb C
20v, 15v , 9v & 5v
Do these just auto switch ?
I want to find a 5v item to test it on as I have a good use for this , Mister fpga if it’s safe as a 5v psu
Brettster
20 (100%)
1,257CR
Those are the usual PD standard outputs, so any decent USB C PD PSU can do that, if you want a specific voltage you can use a PD trigger board or adapter, I have a few of these to run a Mega Drive, SFC or PC Engine from a USB C cable.
Very handy
8,051CR
Very handy
Cheers for Thats
What is PD ?
Power distribution ?
pd trigger board sound interesting 👍😁
Will take a look ..
One psu to rule them all ?
Which trigger boards do you recommend ?👍
Brettster
20 (100%)
1,257CR
PD = Power Delivery, USB C can negotiate the power it needs
the triggers can be something like these https://www.amazon.co.uk/VOANZO-Trigger-Charging-Delivery-High-Speed/dp/B0DMCRPTV6
where you set the dip to the power you want
or https://www.amazon.co.uk/JZK-adapter-connector-5-5x2-1mm-adaptor-Black/dp/B0FL2G1K5M
direct to a barrel jack, just make sure you pick the right voltage / Polarity as they cannot be changed later
also these are much cheaper from Ali Express, but you get the general idea
8,051CR
Thanks Brettsrer
I can trial it on something els 5v before my misters 👍
