Lesson learnt today !
Was having issues with left and right triggers on a Nintendo DSI
The give a big blow trick worked for about a day so decided to strip down and clean properly !
My handy hint is don't be too vigourous on the button as the bloody rubber piece pinged out the button switch , never to be seen again !!
All I can now see if the metal disk !!
After much searching the floor , to no avail. I found this on ebay thank goodness.
https://www.ebay.co.uk/itm/Flex-cable-for-DSi-Nintendo-SD-card-reader-slot-L-R-shoulder-button-ZedLabz/273929682458?epid=1122829944&hash=item3fc77b3e1a:g:a5AAAOSwTdpfNKkU
I was so pissed off when it flew out . I bet I will find it just as this £7 part arrives !!!
GRRR to what should of been a 5 minute fix . on first attempt only 1 button came alive, so decided to use a toothbrush rather than the cotton bud , then PING it went !!
You can only find hole buttons on ebay and no actual videos of them being de-soldered and look pretty tricky so buggar it the £7 will be worth it !
Thought my mess up may help others !
