I am pretty sure we have some carpenters and builders in this forum
Just going to refurb the kitchen with new doors/plynths and a worktop for utilty room. Already had main worktops in kitchen replaced by a professional.
All the plinths I am having to make from cutting a larder panel down. Long Story but the gap from floor to bottom of cupboards is more than the standard 15cm plinths. My fault when did kitchen originally the plyths were higher than the normal 15mm!!
Its ok found an end lanel which is 2.4 meteres so wil be able to make two 2.4m plinths from it !!
Last time i fitted my kitchen when was doing the whole house up and had sod all money I did it all by handsaw and jigsaw, which was time consuming !
I want to refresh the kitchen and happy to get a circular saw but finding it all a bit confusing.
I dont currently own a circular saw so thought would reach out for advise
I was considering buying a track saw bundle
Evolution Bundle
That seemed fine for cutting my plynth lenghhs and producing a neat straight line. But the more I read o internet they recommend a 60T saw and a evoution dont do a 210mm 60T and they seem to have their unique bore hole size which is not compatible with other blades
The plinths you dont really see under the cabinets but would like a neat finish on my utilty room worktop.
I am pretty sure we have some carpenters and builders in this forum.
Can you recommend a circular saw which could be used for plinths and worktops that I wont have hassle getting blades for.
I dont mind spending a upto about £200/250 as I dont own a circular saw and is a lot cheaper than me paying somone to fit kitchen.
I dont mind wired as would a cordless be powerfull enough for 38mm laminate etc Do i need a 210 235 ??
Really want to get a saw that will do this job but also do general cutting 2x4 etc appreciate will need different blades.
Also and excuse my thickness I also need to MITRE the cornice and plinth on top of cabinets. For that should I buy a seperate mitre circ saw or if I get the right one can I buy an accesory to put it in ?
Never had a circular saw and effectively I have two main jobs worktop/plyths and mitre. Oh and will need to cut hole in worktop for the sink.
Any help appreciated . I think the evolution would of been ideal if they would have done a 60T blade, but would of then have to have bought a mitre saw. mitring using a block and saw is a bit crap when I do it
Any guidance really appreacite.
Evolution Bundle
