Wasn't sure if I put this in here or the workshop update thread, but here seems more the right move, as I've already mentioned it above.
So just before the weekend we had an issue with the metal guillotine being behind a load of machines and more importantly, in bits.
We need this in order to cut the sheet steel down to size. The supplier of the 8' x 4' sheet cut it into quarters, to make it easier to transport, but even that cutting service cost £10, $14. If I wanted them to cut it into the correctly needed size, that's £60, $80. Yes I know it's time taken and wear and tear on equipment, but that seems a little excessive. So pay for the initial cut, and do the rest myself.
First up was getting all those parts out of there. Not an easy task and some of these weigh a fair amount of weight, but for someone who seems to shift cabs around more than they should, all was eventually managed. Next up, finding all the parts. I know there around here somewhere, but where . . .
All lined up, power hosed and the greasy, oil drenched parts degunked. Everything eventually laid out and working out what goes where.
Gave the nameplate a good clean, blacked the background, and polished off the highlights. You can even read the model number now.
and start painting.
This is an F.J. Edwards metal treadle guillotine, meaning you use your leg power. Founded in 1916 as the Belgian Specialities Co., the firm formally transitioned into F.J. Edwards Ltd. in 1917. They heavily marketed their sheet metal machinery under the Besco brand name, which this is one of them.
There are two more labels on the side, the makers one and another brass one all covered in paint. Time to see what's hidden beneath.
Hmmm, plant number 58. You can even see the scribe lines to help keep everything aligned. Didn't help much, lol.
Looks like it was originally part of a large manufacturing group, and this was part of plant 58 metalworking shop.
The paint had definitely seen better days. All a range of various colors, chunks taken out, scrapes and a mad amount of rust in some places. This was cleaned down as best as I could, smoothed out the rough spots, and removed the rust. Can't just leave it sitting all multi-colored so let's get mucky
With everything all looking purty, it's time to start assembling. It's all fairly easy to put together, but again, heavy lifting.
A few test cuts and blade alignment, and she's good to go.
I've a few wee updates I'm looking to do with this. Currently there's no way to ensure your cut is a right angles to the blade, so a nice stop would be good. Also a tape measure so I know how much is at this side of the blade. The cut off part behind the machine, just falls to the floor, so a catch area would be useful, these ol' legs and back aren't what they used to be, lol.
I'll get these added over the next day or two and get cutting. Also have to work out another jig to aligning the holes and cutting the tabs that hold the leaf switches.Maybe this weekend we can start on the lower frame section.
