Sanwa 29e31s live /neutral
james197
59CR
Hi all, just needed a heads up if possible, anyone know what pin on the AMP connector is live and what is neutral for the 100VAC lines? Pins 6 & 7 are listed in the manual but neither is specifically mentioned as live or neutral.
I’m guessing 6 live and 7 neutral given the wire colours but just wanted to double check.
Cheers in advance
tb2000
3,231CR
It runs from a 100v isolation transformer so it shouldn't really matter which way around (i've run Sanwa 29e31s from a 128v Hanty iso and a 120v WG iso with no problems). With that said, your best bet is to follow which wire goes to the fuse on the chassis, that'll be the equivalent of the live one.
4,720CR
Just took the transformer out my cab, that's how this was connected up though it shouldn't matter which way the blue pink is but monitor connector is pink far right pin, blue to left
