Problem Sanyo EZ20 Dead?
jerryspaghetti
32 (100%)
1,790CR
I have a Junior cab that's showing zero signs of life from the monitor. I have audio from the game but there's no neck glow, no hum and no static from the screen at all.
The two glass fuses are both good and there's no obviously blown or leaking caps and no flyback leakage to note.
I thought it might have been the internal 100v socket but ruled that out as I am getting audio so the sound amp in the monitor must be getting power. I can also adjust the volume.
The neck board is connected well and everything else looks normal in terms of connections. The horizontal test switch is in normal position also.
I'm at a loss to work out what it is without investing in a flyback from the US and a full cap kit but I really don't want to pour money into a monitor that's dead. It has a fair amount of DK Jnr burn too whereas I might pour a bit of money in if the tube was really nice.
Is there anything obvious i'm missing?
jerryspaghetti
32 (100%)
1,790CR
B+ voltage is a big fat zero.
Tried adjusting screen voltage, b+ pot and even horizontal hold on the chassis and no joy.
apart from the sound amp working the screen is the same whether it’s turned on or off! Dead as a dodo 🦤
jerryspaghetti
32 (100%)
1,790CR
Does the 100v plug socket have power?
Is the HOT good?
Yeah, 100v socket is good. Need to check the HOT tonight.
I think i'm going to swap out the horizontal hold pot too as the guy I got it from described problems relating to that area and that it was powering up a few weeks ago.
Unfortunately he had it stored in a place with no power so couldn't show it working before I took it away.
gunblade
22 (100%)
8,760CR
0v on b+ would point towards a blown fuse but depends on where you are reading, there is a mains fuse and a b+ fuse. If a fuse is blown there is a reason for it and depending on which fuse then depends where to look for the culprit
the way you are trying diagnose this is not logical
jerryspaghetti
32 (100%)
1,790CR
Both the AC and DC fuse are definitely not blown
