Short on a Pacman PCB
wishiwas
1CR
I have a PacMan board that has a short somewhere. The voltage at Q6, IR1 and the caps are too low and one of the ground wires going to the header connector gets hot.
Is there a common component to check? I looked at all the caps close to the rails and they all look good.
I just unsocketed all the socketed chips. When I ring out a socket (top pin on right / bottom pin on left) every one of them rings. My working board doesn't
I have a multimeter, probe and Oscilloscope, but I dare not apply power to the board again until I fix the issue. The power wires going to my switching power supply got hot!
sukhbir
45 (100%)
1,606CR
Has this pacman pcb ever worked?are you using a switch mode power supply or AC transformer to power your pcb?
if you are using a switch mode power supply and your pcb has a short the power supply goes into protect mode and should not pump high amps into your pcb.
wishiwas
1CR
I am using a DC switching power supply. I works just fine on other "working" boards. There has to be a short on this board somewhere because the wires heat up when I ring out certain areas vs the working board, it rings when it shouldn't. I replaced the TIP31C and the 78GU1C last night. No change.
qjuk
48 (98%)
1,774CR
Are you working on an original Namco/Midway board or a bootleg?
When you say “ring out” are you on about a continuity check using a DMM (digital multi-meter)?
Bad capacitors can cause shorts (even if they physically look fine).
Hexen
487CR
Any Tantalums about? Damaged disc ceramics? I would suspect a Tantalum. Wires getting hot is better than ICs, but do any of the components get hot? I guess it's the 5V line? Can you post a schematic, there are lots of pacman boards.
What do you mean by 'ring out'?
wishiwas
1CR
Yes, continuity using dmm. On a working board, it will ring for a second or so until the juice of the cap is exhausted then stop. This board it just stays ringing. I moved onto a Galaga issue but I am coming back to this board today. I will try clipping one side of some caps.
