Snow Bros PCB Power Issue
ptom98
23CR
Having an intermittent issue with a Snow Bros PCB where sometimes it doesn't power on.
It I initially had sync issues and audio issues, but resitting the socketed chips, giving it a little clean and replacing the audio amp fixed those.
When it boots up it works without issue, but there's been a couple of instances where it doesn't appear to power on.
I have it connected to a HAS SuperGun, and when this happens the voltage meter on there also doesn't turn on, unplugging from the JAMMA harness and plugging back resolves it, but am concerned that it's the sign of a future potential issue/something I should be concerned with.
I've done some minor repairs on boards before, but not to sure where to start on this one, any advise works best useful :)
ptom98
23CR
When not being used, no PCB is plugged into the HAS but the Mean Well is plugged into the wall socket but turned off.
Lurch666
21 (100%)
4,180CR
What's probably happening is your snow bros has a slightly smaller edge connector than the socket and sometimes it's off enough when you plug it in to short the GND and +5V that are next to each other on a jamma. This would cause your PSU to instantly cut power. When you unplug and then plug it back in you must be fitting it better so it's no longer shorted.
qjuk
49 (98%)
1,787CR
The only other slight issue I can possibly think of that there is not quite enough (or a boarder-line) load on the +5V for the Meanwell PSU to fire up. Snow Bros is a small pcb and I don’t think it draws much.
Often, if there’s a short the PSU will shut down for a while before it will work again which makes me think it’s not actually an issue with how you are connecting at the edge connector.
Edit: If it’s an original Toaplan pcb, the edge connector pins are properly spaced and you shouldn’t be able to accidentally connect it slightly off, unless of course someone has filed down the edges of the pcb or some reason or your JAMMA connector housing plug is damaged at the side/s.
