Space Invaders MB14241 Shifter Replacement
philmurr
48 (100%)
2,362CR
Some of the original Taito/Midway SI style boards have a Fujitsu MB14241 shifter chip to help move the graphics around, these days a lot of them have rotting legs or are faulty. Replacements are fairly difficult to find so whilst I know there are reproductions boards using a number of TTL chips I decided to make my own more compact (only a bit bigger than the original chip) repro using a CPLD.
The code fits nicely into an ATF1502AS and following a bit of testing seems to be working nicely. Photos show the Space Invader test ROM indicating all is good with the shifter, the replacement CPLD board installed on a Taito 2-layer colour SI board, and Lunar Rescue (which gives the shifter a good workout) playing without issue.
philmurr
48 (100%)
2,362CR
Will you be selling any blank 24 pin CPLD boards like you did for the 28 pins?
I didn't think there would be much call for them but can sell you a few if you're interested. You'll need to "hack" a JTAG interface board to put power to the right pins but it's only a wire
