Spinner help...
councilface
152CR
For some reason my spinner isn't registering fast inputs. I'm using recalbox (retroarch) in combination with a baolian spinner. No matter what I adjust sensitivity too it doesn't seem to like fast inputs. Any suggestions will be gratefully received!
chubsta
475CR
I have the same spinner and when I first got it it was too slow to play arksnoid etc. they upgraded it and I bought the new board for it which allows you to adjust the sensitivity via dip switches on the board, now it works great.
Which spinner board do you have, old or new?
councilface
152CR
I have the new one (v2), with dip switches. Ive just discovered that it works great for tempest but it doesn't recognise the much needed fast inputs to rescue me in Arkanoid!
councilface
152CR
Gaaaah!
Now that I'm loading Arkanoid through MAME rather than FBNeo I'm unable to select Mouse as an option in the retroarch menu. Consequently I'm unable to use my spinner in MAME:1000016123.jpg
This what the controller menu looks like in retroarch in FBNeo:
Lol!
Any help offered will be gratefully received!
CF
chubsta
475CR
Have you tried setting it up in the mame tab menu - don’t think I bother going into retroarch but will check in the morning
As I said, I use batocera which is incredibly easy to setup so perhaps thats an option?
councilface
152CR
I'm running arkanoid through MAME 2003 plus. It sounds as though I may have to edit a config file. I'll do that and report back!
chucky87270
0CR
Hello, I have the same spinner from Bealian as Spinner v2, but I can't get good game speeds under Recalbox and Retroarch. Who managed to configure it on this hardware?
Thanks.
