Stepdown Question
Milky
16 (100%)
1,037CR
Having a bit of a senior citizen moment. I've bought another stepdown from maplin after the existing one gave up....
http://www.maplin.co.uk/p/maplin-230v-to-110v-300w-voltage-converter-vr05f
...and realised that I've only ever run US kit off my old one. So, am I okay to run 100v Jap machine on this 110v US plug? Never considered it before. Usually wouldn't be too worried but we're in "frying £500 of kit" territory
Milky
16 (100%)
1,037CR
guddler said:
Not sure on the voltage. Probably. But what kit are you running off it? 300W isn't much!
It'll be the FM Towns I picked up earlier in the week. I'm a bit wary about this TBH but can't find any (non-dodgy) sites that sell proper 100v stepdowns!
anj
313CR
the jap stuff is 100v on the dot , and i have blown jap stuff up using a 110 step-down, i do have a spare 230 - 100v 800kva stepdown if thats of use to you
Milky
16 (100%)
1,037CR
Thanks for the info dude! That would be my worst nightmare so definitely going to ignore the 110v and go for a 100v converter. Dad reckons he's got one buried in his loft from the days when he had some bells-n-whistles 70s Japanese hi fi set up so will see if I can dig that out first. Thanks for the offer too - i'll let you know
anj
313CR
i think it depends on the tolerances of the step down , dome of the maplin/Chinese stuff they over volt stuff , i had a maplin 110 that was spiting 150 v out so just be careful
simonden
20 (100%)
1,042CR
A lot of it is down to tolerance, in the EU the required tolerance is -10% +6% hence that 230v can be used anywhere in Europe (220v-240v).
Not sure of Jap regulations and we are talking about equipment that was manufactured when regulations were probably not as strict.
4,058CR
Try "AirLink Transformers":
http://www.airlinktransformers.com/japanese_voltage_converters/japan_uk_voltage_converters/UK-JA0250/
Not cheap by any means, but I'd trust them 100%.
Not sure on what VA you'd need. Do you know the current draw of the console? I had never even heard of that console until you posted the pic of it. Should be able to work out the VA you need approximately. I think I've got a simplified calculator in the reference section of my website. Just make sure you add in some headroom.
The reason I mentioned the 300W not being enough is because I've seen a 300W Maplin US step-down quite literally melt after the owner ran an Asteroids Deluxe off of it for a few hours
Quite amusing, really, but in fairness it was actually dangerous, if there hadn't been a lot of people around and someone playing it, it could have gone un-noticed and caused a fire!
