TECH: IC Tester
peterbudduk
18CR
[ukvac] TECH: IC Tester
Guys,
I am about to build an in-circuit IC tester based on something I saw on
the 'net a few months ago (but I cannot find it now).
It works as follows, it compares the outputs of the IC on the PCB
("device under test" or "DUT") with a known good device inserted into a
ZIF socket of the tester. The way I was going to build it was to have
an array of switches one for each pin of the DUT. If the pin is an
input then the switch would directly connect the DUT with the known
good device. If it is an output then the switch would connect the
appropriate pins to an exclusive or gate to indicate via a transistor
and a LED (and possibly a pulse stretcher) whether they are behaving
the same way.
It strikes me, however, that there could be a simpler way that avoids
the use of switches and exclusive or gates. If every pin (ignore
power) of the DUT was connected to the known good device via a
resistor, then the transistor and the LED could simply detect whether
there is a voltage drop across the resistor. Unfortunately, I do not
know enough about the input impedances of TTL ICs to know whether this
is feasible. Bear in mind that I will probably be testing a mixture of
TTL and LSTTL ICs. Any comments would be very welcome.
Note that I am aware that an IC tester of this sort will not be a
panacea - it is primarily intended as a quick test to spot likely
problems.
Peter
ebates.com. Earn up to 25% cash back for shopping online at 75 stores
like Borders, CDNow and Beyond.com. Refer a friend and earn even more!
http://clickhere.egroups.com/click/690
eGroups.com home: http://www.egroups.com/group/ukvac
http://www.egroups.com - Simplifying group communications
4,995CR
[ukvac] Re: TECH: IC Tester
Hi Peter,
>I saw on the 'net a few months ago (but I cannot find it now)....
>problems.
Rather than building one why not just buy one?
Hewlett Packard make just such a device, it's called a "Logic Comparator". I've
seen them pop up at radio rallies from time to time, in fact I got mine from
such a rally a few years ago for 35.
They're worth they're weight in gold when trouble shooting boards that you
don't have the schematics for!
Just don't ask how much they are new...! ;-)
TTFN - Pete.
Hardware & Software Engineer. Sound Engineer.
Collector of Arcade Machines, Games Consoles & Obsolete Computers (esp DEC)
peter.pachla@virgin.net |
peter.pachla@vectrex.freeserve.co.uk |
peter.pachla@wintermute.free-online.co.uk | www.wintermute.free-online.co.uk
DATA Imported from archives: originally posted by Peter Pachla (peter.pachla@vectrex.freeserve.co.uk)
4,995CR
Hi Peter,
>problems.
TTFN - Pete.
G-man
180CR
At 14:46 10/08/99 +0100, you wrote:
>Hi Peter,
> >problems.
I've
And if you *really* want to go to town, try ABI Electronics
who do a 40pin out of circuit tester (amongst other things),
their stuff is really good. (I have the Boardmaster 4000).
http://www.abielectronics.co.uk/
Graham
G-man
180CR
>Hi Peter,
> >problems.
I've
Graham
32CR
Simply connect the two devices (target and test) together pin to pin with 1K
resistors (ish) and use an array of octal comparitor ICs to compare each pin
(inputs and outputs). Cascade the results of the comparitors and stick an
LED on the output. This will not require any DIP switches. Easy.
I'll try to prototype one this week. If it works, anybody interested in
getting some made ?
Mike Walden
zepromz
77CR
>getting some made ?
Yeah, could be good.
end
|----------------- P3TE - skitzo@dircon.co.uk -----------------|
|- Cardiacs / Thrash Metal / Arcade collecting / Guitar Tech --|
|---------- http://www.skitzo.dircon.co.uk/index.htm ----------|
Listen to Britany spears and more top artists
now at audiohighway.com!
http://clickhere.egroups.com/click/395
peterbudduk
18CR
Mike,
I wish I had seen this post before - I have just protoed a PCB doing it
"the hard way" with switches and the like. I even made it suitable for
home construction - single sided with nice wide tracks.
Let me know how your prototype works although I think that more useful
information could be had if the outputs of the comparators were not
cascaded and there was a LED for each pin.
with 1K
each pin
stick an
in
> getting some made ?
> Mike Walden
