Tech : JAMMA Cab - Further Info.
4,993CR
[ukvac] Tech : JAMMA Cab - Further Info.
Thanks for the advice received so far
ref. the lack of coin input and sound output
on my JAMMA Cab.
I have checked the earth connections and there does
not appear to be a problem there.
I have not yet had chance to check the fuses in the PSU
but would like to confirm that, everything else works OK, the
games come up on screen and joystick/buttons are OK. It is
purely the fac that there is no sound and coins/credits
are not accepted.
Something else to mention is that each time I reset
the machine at, when powered back up 1 Credit is automatically
available for play on several PCBs where normally this
doesn't happen. This happens on Major Title and Power Spikes
(naff games I know!)
It is almost as if 1 credit / coin is being registered
when the power is switched on.
Immediately before this problem occurred, I had ben changing
the Major Title PCB for the Power Spikes PCB. Upon first power
up with the Power Spikes PCB installed, no display came up
and a high pitched whining noise was emitted from the cabinet.
I detached and carefully re-attached the JAMMA connector
and it powered up OK after that but without sound and
coin input. These 2 PCBs have since been tested in my
other, older JAMMA cabinet and they work fine in every respect
so the PCBs are not damaged.
Is it possible that by mis-aligining the JAMMA connector
I could have caused this problem? Unfortunately there is a
small amount of leeway when connecting which in its worst case
could have led to each pin being connected to the one adjacent
to its proper position e.g. PCB Pin 5 being attached to Jamma
connector Pin 4.
Sorry to ramble on, I'm just hoping that this info. may
shed further light on the problem.
Thanks Again
Jason Howle
Java or juggling?. Everybody learns something at Learn2.com. Where
you'll find thousands of free 2torials, affordable online courses, and
useful tips for everyday life. http://clickhere.egroups.com/click/964
eGroups.com home: http://www.egroups.com/group/ukvac
http://www.egroups.com - Simplifying group communications
DATA Imported from archives: originally posted by (ziggy@stardust.force9.co.uk)
