TECH: Monitor Synch Question
MarbleMad
106CR
[ukvac] TECH: Monitor Synch Question
I have a Hantarex MTC900E monitor which I want to run some arcade boards
on but the thing only appears to have horizontal and vertical sync
inputs, no composite. I've been told that some people have had success
with this monitor by simply connecting the composite sync to the
monitors horizontal sync but this just doesn't appear to work for me.
I've tried connecting the comp sync to the horizontal, vertical, and
both at the same time but the best I can get after much adjustment to
the various post at the back of the monitor is an image that slowly and
steadily moves in both the horizontal and vertical axes.
Anyone know of something else I could try.
I'm also told I could build a circuit to split the comp sync into a
vertical and horizontal sync. Can anyone tell me how to build such a
thing?
James G Watt
http://www.kinetic-arts.demon.co.uk
Part of the Video Arcade Game Collectors WebRing.
You are in a maze of twisty little passages, all alike.
ebates.com. Earn up to 25% cash back for shopping online at 75 stores
like Borders, CDNow and Beyond.com. Refer a friend and earn even more!
http://clickhere.egroups.com/click/690
eGroups.com home: http://www.egroups.com/group/ukvac
http://www.egroups.com - Simplifying group communications
P-Man
International man of mystery
1,272CR
[ukvac] Re: TECH: Monitor Synch Question
I've had some problems with these in the past not syncing properly..
Continue as you've been told though, connect the JAMMA comp. sync to the
horizontal sync line and leave the vert line disconnected..
find the horizontal hold pot and play around with that until you get a
picture.. I had a very frustrating time where only one board would sync up,
the rest were all screwed... just stick at it, you'll get it eventually..
seeya!
Andy Welburn - A Collector of fine video game antiquities
http://www.willowsp.u-net.com/andy/collected.htm
>> CURRENTLY MOST WANTED <<
Machine gun/optics for Operation Wolf Coin-op.
MarbleMad
106CR
In article <001601bee358$94b3ef80$170aa8c2@wendywel>, Andy Welburn
<andrew.welburn@cableol.co.uk> writes
Is the horizontal sync the same as the horizontal frequency?
(the monitor only has horizontal and vertical frequency and shift)
Yes. This is what I did after reading randy fromm's tips on that monitor
but the sucker will just not synch. I've turned the horizontal frequency
from one extreme to the other and back.
I did notice one thing looking at the board and schematics. The
horizontal synch that I'm using appears to be a + horizontal sync.
Behind that there's a 3 prong plug with a - horizontal sync (gnd -v -h).
Is this perhaps where I should be connecting the comp sync? It's a -
comp synch after all, isn't it?
James G Watt
MarbleMad
106CR
James G Watt
5,013CR
Hi James
I use these monitors & the 9000 models all the time without
problems on pcb's ranging from St fighter to NEO Geo etc. etc.
Is the monitor ok ?
cheers
TMC
DATA Imported from archives: originally posted by TONY MCLAUGHLIN (JA.McLaughlin@ulst.ac.uk)
5,013CR
Hi James
Is the monitor ok ?
cheers
TMC
MarbleMad
106CR
In article <199908110827.JAA18125@ramore.infc.ulst.ac.uk>, TONY
MCLAUGHLIN <JA.McLaughlin@ulst.ac.uk> writes
>Is the monitor ok ?
Well it works perfectly with the system1 board it came with.
James G Watt
MarbleMad
106CR
>Is the monitor ok ?
James G Watt
MarbleMad
106CR
Solved the problem. I found a -V and -H synch connector BEHIND the +v
and +h and thanks to bob roberts I got it working by connecting the comp
sync to both of these.
Thanks everyone for the help.
James G Watt
