tech: Vector monitor
marog_uk
33CR
I'got a technical a problem with a Hantrex Vector monitor fitted to an Asteroids clone. The following links should show you want the problem looks like when the machine is in test mode:
http://www.marog.freeserve.co.uk/images/asteroids1.jpg
http://www.marog.freeserve.co.uk/images/asteroids3.jpg
I think I saw a post a while back from someone with a similar problem, can't find it in the archives though. Any advice or pointers to helpful information anyone could give would be most appreciated. Cheers, Steve
Get more from the Web. FREE MSN Explorer download : http://explorer.msn.com
5,289CR
Hi Steve
It looks very much like a problem I had with my asteroids
it was traced to the asteroids pcb and not the monitor
it was in the Y output section of the vector generation circuitry
traced to a couple of TTL's
if you check to see which of the TTL's have pcb tracks going to the ADC's then you will have a good idea on which ones to start replacing
Mark
DATA Imported from archives: originally posted by markgwilliams (markgwilliams@ntlworld.com)
marog_uk
33CR
Re: [ukvac] tech: Vector monitor
Mark,
You are right it is the board. I connected a scope upto the X & Y outputs
on the board and got the same result. I shouldn't have asumed it was the
monitor without checking first!
Cheers, Steve
>From: "markgwilliams" <markgwilliams@ntlworld.com>
>Reply-To: ukvac@egroups.com
>To: <ukvac@egroups.com>
>Subject: Re: [ukvac] tech: Vector monitor
>Date: Fri, 8 Dec 2000 13:46:54 -0000
>Hi Steve
>Mark
