TNMT Konami strange problem
vas123
14CR
Hello everyone,
I have a TNMT board which has a strange problem. At startup it passes the test and freezes when the clouds appear on the screen. When I put it in test mode everything is ok and works. In a sound test, I don't hear anything I choose. I checked all the eprom and they are ok. The sockets on the chips are perfectly clean.
Thanks for the advice in advance!
TheDaddy
14 (93%)
7,223CR
Have you checked your voltages to make sure they are all correct ??
Normally a sound issue would not cause the board to freeze either.
Dave.
vas123
14CR
The power supply is perfect. All voltages are absolutely accurate, and I checked them for pulsation with the oscilloscope. I have added additional capacitors at 120,000 uF on every voltage.
vas1232020-06-11 10:52:51
AMS
66CR
You can always sell it cheap to me.. maybe I can help you with the problem then
But I had the same issue in some Konami board and I had up the voltage a tad to get it running.
Monstermug
1,807CR
Some konami boards will freeze on sound problems too. After setup if it will allow, go into test menu and do a Mask Rom Test if that is an option. Let me know what happens
GadgetFreak
961CR
It looks like it's freezing right at the point where the Ninja Turtles sound sample is played. You need to check the sound circuit, most likely the sample playback. If I remember correctly the sample is clocked through using several 74ls163's. Not heard of it freezing a board before though.
Monstermug
1,807CR
Assuming there is absolutely no sound, you might want to check the z80 and sound ram? Or even the LS163's Aaron has mentioned. Schematics are available for TMNT. A good page dedicated to the voice samples too. An audio probe might come in handy just to eliminate an analog fault but I shouldn't think an analog fault will freeze the game, which leads me to think it's more a digital fault. It could also be two separate issues as well so I wouldn't dismiss that.
vas123
14CR
The Konami 007232 PCM controller is showing activity on the CPU lines,
it has power, and it's getting a clock signal, but the ROM address and
data lines are stuck low with no activity .ROM pins 14,16,18,20,23,25,27
Any ideas?
vas1232020-06-13 08:16:39
TheDaddy
14 (93%)
7,223CR
Could be Ram / Rom ?
Is there any activity before it freezes ??
Dave.
P.S as I said its strange as audio faults don't normally cause this. If the main CPU has froze then there will be no signal to Audio CPU and this will stop the audio from working and give Low signals.
vas123
14CR
Hi, Dave,
I cheked all eproms ,and the status was good. No, activity before it freeze, but X2 640 Khz. resonator is connected to sync signal on custom konami chip is freeze both with picture.
Regards!
vas1232020-06-13 12:35:01
TheDaddy
14 (93%)
7,223CR
Could be the Custom then, But on saying that it could be anything I suppose we are just guessing. Without physically having the board there is not much else I could advise.
Dave.
P.S I have not done any of these but I know the customs ruins a lot of simpsons / TMNT boards.
vas123
14CR
I pulled out custom chip Konami 007232 and ... still pcb freeze on the clouds.Now i am looking for a new chip to replace it.
