Tournament Arkanoid PCB Repair
qjuk
50 (98%)
1,838CR
You’re right Vamino, I had the wrong part number for the 12 pin. You are correct it’s 3.96 pitch and not 2.54 which I originally wrote. My apologies buddy. I’ve updated the link incase anyone else in the future uses it.
However, my spinner connector is definitely also 3.96mm pitch. I’ve got a bag of these here and have actually used one to replace a broken header on an original Taito pcb and it fits perfectly. Are you sure your spinner pcb pin connector is 2.54mm pitch?
Vamino
Insert coin(s)
22 (100%)
2,631CR
The spinner is boxed up in the loft, it's an original Taito one so if yours is definitely 3.96mm pitch then mine will be too.
I'll edit my post too to remove the 2.54mm pitch.
Cheers.
