UKVAC Image Upload - FREE Software
TheDaddy
14 (93%)
7,059CR
Hey All , So like many i upload a lot of pics and although there is many of free ones out there they are not doing what i realy wanted !!!. What i needed was a basic piece of software that took and image and compressed and resized the images until it was under 2mb.
So I set about making one and it works well, Been using for a little while.
The conversion is based on standard JPG - The size will be reduced if needed. It gets as close to 2MB as it can but depending on pixels ect conversion and be a lot lower.
I am currently tweaking it a bit but I will add the zip for people to download and use - Free of charge obviously.
Very Very easy to use :-
click "Open" button - select file
Click "Convert" button and done !!!! upload
Filename its save the same with "-Converted" at the end.
If file does not need converting it will say "CONVERSION NOT NEEDED"
This is the outputted file here :-
Windows conversion Data :-
I hope people want and will use this !!!
Leave a comment if you want , Click the 'Thanks' as well if your feeling generous !
DOWNLOAD HERE :- https://www.ukvac.com/forum/data/uploads/4711/UKVAC_Image_Converter.zip
Cheers all ,
Dave.
P.S Was unsure where to post this ??
P.S.S Sorry its not very flash !!
TheDaddy2021-07-22 09:59:50
939CR
Sounds good, currently I open a picture in Microsoft Office 10 picture viewer and hit the compress button until it gets to a smaller size.
El Capitan
Max 330 Pro-Gear Spec
98CR
I used to use something called resizemypictures.... it was super easy and once installed, you just right click on the picture and its there in the menu.
TheDaddy
14 (93%)
7,059CR
Thanks Guys - Added the Zip file (First Post) - Just download and extract the EXE to wherever you like and run.
If you have Antivirus that has SHA256 recognition then its = 3144D79548D8D2CDEC254EB1A884E740CCADE8DA82BD2DFF837E24BDACB679EA
If you have any issues please pm or message me here.
Dave.
TheDaddy2021-07-22 09:59:12
