XBOX 360 powered through JAMMA edge connector?
retrob
41CR
I think I know the answer already but would like to know is it possible to bypass the original XBOX 360's PSU and power the console directly from the JAMMA edge connector.
From a quick look the 360 requires a 12v, 5v and a Ground input. So the JAMMA PSU supplies the correct voltages.
But am I right thinking as the JAMMA PSU only outputs ~2.5A on the 12v and as the 360 brick supplies 14.2A that the JAMMA PSU isn't supplying anywhere near enough current to do the job?
Flinnster
The Dino King
29 (100%)
2,566CR
Yeah, jamma switchers are primarily 5V based (15A or so there) and 12V is secondary, usually putting out a max of only 4A.
You could likely rig up a Naomi or PC ATX psu though, in place of the switcher.
