Zenitone Microsec Invader's Revenge
philmurr
46 (100%)
2,316CR
I posted this over on KLOV when VAC was being ported but thought it may be an idea to post it here too with it being about a UK-designed and built game that more people would remember.
I was recently reminded about Invader's Revenge that I remember playing in my younger days on holidaty in Scarborough. More than just a clone of Space Invaders, with "interesting" sounds and varied gameplay.
It was made by Zenitone Microsec from Burton-on-Trent. Whilst it ran on Taito or Midway Space Invaders hardware, it used a custom sound board, either a potted epoxy version for Taito 2/3 layer Space Invader's boards (giving colour or black & white game) or a single board that plugs in to either Taito or Midway L-shaped boards for a black and white game. Without the sound board, the game doesn't have any sound, in fact it doesn't even run and just crashes. Until recently, Mame didn't emulate the sound so I guess not many people played it in Mame as it was silent.
I set about a couple of things - 1-get my stack of Invader's Revenge sound boards working, and 2-spend a bit of quality time with the game code to find out why it wouldn't run, and convert it to have some sound with a standard SI sound board so more people can enjoy it.
I had to do approx. 75% disassembly of the game code to understand what was going on but all is now complete and you can play it on ordinary SI hardware and enjoy some sound, not as many sounds as the original but I've tried to make best use possible of the 6 or so sounds that are available on a standard SI sound board. It also took a lot longer than expected due to some devious code protection in the game (not surprising I guess considering the Stamper brothers were involved in making it...).
1 - A simple one, it checks for the presence of the sound board or else it crashes before even starting up. Code checks for a logic 0 on a particular input so simple to fix
2 - It does a slow running routine to make a checksum on the contents of the game ROM. If the checksum is wrong the game will crash, but not until a few minutes have passed.
3 - Text printed on screen looks up contents of the first 256 bytes of ROM, so if the ROM code has been changed, odd characters are printed
4 - A further, obfuscated code copied from ROM to RAM checks if the sound board is connected. But this time it checks for a logic 1 on the input mentioned in point 1. A command is written to the sound board to change the signal from 0 to 1. If it doesn't read the correct value it (very) slowly updates a timer and eventually the game will reboot, but only after a lot of games have been played. Mame doesn't emulate this properly as it always assumes the signal is logic level 0, and whilst it looks to be ok and plays fine, the game will eventually reboot.
There was very little spare space in the ROM to add the extra sound code but removing the above protection and some of the printed text in demo mode gave me enough space to play with. I also squeezed in a freeplay option selected using a spare DIP switch.
Photos of the different sound boards are attached as are a couple of youtube links showing gameplay using standard Space Invaders sounds.
It's undergoing a bit more testing at the moment, but code should be released soon for anyone who doesn't own one of the sound boards but wants to play the game. It will also star in the upcoming "alternate-SI multigame".
Normal gameplay
In freeplay mode
Paulieboy
35CR
Normal gameplay
In freeplay mode
View attachment 1009View attachment 1010
Hi Phil Good Job, and if you have a spare Sound Board for the L shape I am still interested for a spare for my 2 Invaders Revenge Machines I have.
Dave Langley was kind enough to let me have a second one and now both my Invaders Revenge Machines are working as they should.
Since I have a CPO and Bezel for the Midway I might even sacrifice one of the poor Midway SI Cabs I have into one as well so another sound board would be useful until you get the multigame up and doing. Keep up the Good Work!
Vamino
Insert coin(s)
22 (100%)
2,621CR
Interesting project mate. (y)
I have a Taito Space Invaders Part II PCB so would be interested in a Multi if it's not too much hassle to install. I was hoping to put a subwoofer in the cab to accentuate the bass but for some reason the bass sound effect is a bit weak sounding. I've no idea why that is.
philmurr
46 (100%)
2,316CR
Afraid I only have spare potted boards for the 2/3 layer pcbs. I only have the one L-shaped so I need to hang on to that. I do need to document how to connect up to the potted sound board at some point.
On Taito boards each of the sounds has its own volume pot plus an overall volume control. Maybe the "thump" pot is turned down low?
The multi should plug in to where the 8080 CPU goes. Simple, as long as the CPU is socketed...
