ukVac.com Homepage
  New Posts New Posts RSS Feed - Evolving Drift - Initial D Restoration/Conversion
 Post Reply Post Reply Page  12>
Author
Message
whitecomet View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (1) Thanks(1)   Quote whitecomet Quote  Post ReplyReply Direct Link To This Post Topic: Evolving Drift - Initial D Restoration/Conversion
    Posted: 15 Jun 2016 at 9:39pm
So after owning a couple of these and regretting it every time I sold one, I have no decided that this is the final cabinet. After looking around and finding nothing about it looks like I'm going to have to convert a cabinet into an Initial D, well after how many were converted to OR2 its only fair.
I think if I hadn't owned a few previous and have a great fountain of knowledge living up the road (OutRun2) this would be impossible, but I do so shouldn't be hard to build though finding parts will be tricky.
I have started a restoration blog http://www.initiald.co.uk which will update with extra things, but add updates here.
So first post... finding a cabinet shell to use as a donor cabinet. As the cabinet is going to be stripped I mainly was looking for model 3 or older cabinet, since there wasn't any Initial D cabinets around speaking with a forum member I was able to collect a Daytona 2 cabinet shell. Few features are incorrect but what I was after was the base unit. As long as it wasn't damaged it will be fit for purpose as the whole cabinet is going to be stripped, sandblasted and powder coated.
A couple weeks later made the 9 hour round trip and collected the cabinet. On closer inspection it seemed that the cabinet has been built with a little more care than the Initial D cabinets, just little things like brass captive nuts, all parts labelled, different screws to hold down boards etc... So the plan is to tackle each part of the cabinet at a time and hopefully source all the parts from forums, friends and maybe eBay :)
BASE UNIT
So after collecting the cabinet has been stripped and all parts photographed, I have stripped the base unit and checked if its correct for purpose. It seems as though the top lid captive nuts got damaged and the previous owner drilled 4x 5mm to secure the lid :( however spoken with a few people and I can weld these holes then smooth and the sandblast/powder coating will still take to cabinet. Another difference is that on the Initial D cabinets there is only a rear fan on the base, however on these Model 3 cabinets they added a fan to the rear and front of the cabinet to provide extra air circulation. This is a feature that I will be keeping as if anything it will help with the cabinet.
As we speak I'm receiving quotes back in about sandblasting/powder coating, initially it was for just the base unit. However I'm also asking for prices for all parts as this maybe cost effective.
Edited by whitecomet - 13 Feb 2019 at 12:14pm
Back to Top
Alpha1 View Drop Down
Admin Group
Admin Group
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alpha1 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 10:25pm
Cool!!
Wanted: Time Traveller, GALAXIAN 3 THEATER, 80's Namco & Taito games
Back to Top
paulie View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 10:17am
Great stuff, I'll be following with keen interestSmile
Back to Top
Vamino View Drop Down
Avatar
4 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vamino Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 11:57am
So many ID cabs were killed converting into OR2 cabs, and here you are converting a cab back into ID. We need to start a campaign to save more ID and F355 cabs from death by Outrun 2! Smile
You are taking on quite a difficult project tbh mate, the parts shouldn't be a problem if you are patient. There is a guy who has emulated the card reader so that's an option to do away with trying to find a card reader.
http://www.arcade-projects.com/forums/index.php?thread/814-naomi-2-chihiro-card-reader-emulator-initial-d3-wmmt/
One thing you need to be aware of is that due to the wheel being larger on an ID cab the base lid is shorter. The cab you are converting from may have a longer base lid which will restrict opening as it will hit the wheel.
I'll be reshelling my ID jap to Jp metalwork and the last piece in the puzzle was to find a base lid from a later cab (F355 in my case) as it has a section removed on the front edge, I was pretty lucky to find that tbh.
I'll be using the old shell for an ID project of my own, I have most of the parts and have a US OR2 loom as all that's needed is to splice the wiring for the card reader into it. Someone else has first refusal but if they don't want it we could probably work something out if you wanted to go that route.
Anyway, good luck with the project mate. Thumbs Up
Edited by Vamino - 16 Jun 2016 at 11:59am
Insert Coin[s]
Back to Top
Admin Group
Admin Group
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alpha1 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 12:23pm
If anyone wants a proper mint Japanese Initial D3 machine PM me. My friend has one for sale.
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitecomet Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 12:25pm
Thanks for the information... I will look into this if there is any chance someone could measure the shorter base lid for me would be great (I'm currently redrawing the whole cabinet in AutoCAD for my own purposes), creating a complete parts list and also as I have the tools (from creating Naomi Universal looms) will be creating new wiring looms and noting information on this. Basically in the future will have a full database on the cabinet and possible help someone else who is mad enough to try it again.
I will be wanting to restore this with the original card reader (another part to find), but hopefully over a lot of hunting and time I will find all the parts I need to complete the project.
Thanks for the offer and if you have any spare parts please drop me an PM as I'm sure I'll need most parts.
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vamino Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 12:42pm
As I don't have a UK D2 cab I don't know if the lid is shorter tbh, what I do know is that on a Japanese cab they had to revise the base lid to accommodate ID's larger wheel. It may be that the UK cab didn't need modifying.
The length of the UK ID lid is 78cm and from the lid to the plate the pedals are mounted on is a tad over 36cm.
The cab Alpha1's mate is selling is very nice indeed. Tongue
I thought long and hard about buying it myself but I had to listen to my inner voice on this occasion. My UK cab has been super reliable and I already have the Jp metalwork which will be powdercoated when I find a decent powdercoater near to me.
Insert Coin[s]
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitecomet Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 12:51pm
Thanks for dimensions will check when I get home. Also it seems I'm not to far from you so once I get some quotes from powder-coating I'll pass them over.
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitecomet Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 12:38pm
OK so this project went on hold over the winter.... and wasn't sure how/when it would be resurrected as was going to require a lot of support from members via PM/posts etc...  ideally I needed it to be sat next to an original Initial D cabinet and duplicate it that way... :(
Well thanks to forum member Sean we can now continue this project as I had delivered today an Initial D 2 (slave) cabinet. Which I can now use as my model to rebuild and also restore this cabinet back to a single and play eventually 2-player!!! (or site the other at local RC Car Club).
Even though some of my costs have doubled it will now mean there will be twice the fun!! Full photos will be taken later and then moved to project basement for the strip and rebuild :P
Edited by nintendoid - 26 Jan 2017 at 12:38pm
Back to Top
seanr28 View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote seanr28 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 12:41pm
pleased you got it ok! that was very quick delivery indeed!
Back to Top
Outrun2 View Drop Down
Avatar
Colonel Outrun
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Outrun2 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 12:58pm
Superb mate - I do like the iD2 livery as well - probably the least seen of the Naomi based three.
Twins are great.. if you have the space!!
Would like:
No more cabs.. please!!
Back to Top
robotech View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote robotech Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 1:26pm
initial d is so f**king cool nice to see another one being saved/restoredClap
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitecomet Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2017 at 8:31pm
finally got round to seeing the cabinet today and took a load of photo's.
Can be seen here.. http://www.flickr.com/photos/144047309@N08/albums/72157679686870345
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitecomet Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2017 at 11:06am
So this weekend I started to move the cabinet, I had limited time/space to move it to my house. So took the majority of the top off, also was able to stock take on what screws/bolts etc was missing.
Photos loaded to: https://www.flickr.com/photos/144047309@N08/albums/72157676464708943
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitecomet Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2017 at 9:31am
Not a major update as not an awful lot has happened (house duties)... however after some playing at the weekend and trying to diagnose a stuck button (which was stopping the start, view change, credit from working) which Im pretty certain this is a I/O board fault. With this it seemed my monitor was picking up a error, after a few conversations with Gunblade it developed into a nice GPU fault.
So after hunting around for some parts we decided that cleaning and restoring the spare Initial D dashboard was a good idea. We haven't wrote a full post on website as currently we are just stripping the dash apart and logging all the parts. Due to the age of the parts we will be looking at replacing the majority of parts with NOS.
Anyways if you want to see pictures of the strip down of the dash follow the link: https://www.flickr.com/photos/initialdukstage/sets/72157686167682335
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitecomet Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2019 at 2:12pm
wow.. ok this has been a while... so the cabinet itself hasn't moved on much.
I have sourced both the left & right card reader stands, this will allow me to mount the card reader on either side without a coin tower.
GAPH3967 by Initial D, on Flickr
The cabinet base has also been stripped back down to a bare unit, this is going to be shot-blasted and then powder coated at the end of the month.
Reason being for this is due to trying to finish off the basement for the new home of the cabinet and other games.
Edited by whitecomet - 05 Feb 2019 at 2:13pm
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote robotech Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 11:04am
Chequerboarding on the naomi 2 may just be
A bad sram chip run the test see if it comes up with anything
One of mine had the same issue was ok after a chip swap
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitecomet Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 11:29am
Yeah once the cabinet is back together, the Naomi2 boards will all be checked out and work out whats what.... this month is powder coating :)
Back to Top
Mikonos11 View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikonos11 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 1:14pm
Hi whitecomet!
Yes, I´m interested in to help you, I think I told you.
I have most of little stickers you are looking for, About big decals, I have some of them:
I have original "Initial D 2 Topper":
I have scanned "Initial D 1-2-3 Base decals "
I will show you more scans and restorations ahead.
Regards
Edited by Mikonos11 - 11 Feb 2019 at 1:18pm
My mail: midasororey@yahoo.es
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitecomet Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2019 at 12:25pm
thanks Mikonos for links....
So as we are getting parts which are going to the shot blast/powder coating we are having to remove item and stickers etc... next on the list was the base lid.
IMG_1479 by Initial D, on Flickr
The hinge looks to been spot welded on and therefor cant be removed, which means the hinge needs to be entirely coated. I have asked shot blast guy for advice, alternative I can drill two holes and using a pin and hammer get the pin out though would rather not drill extra holes.
IMG_1480 by Initial D, on Flickr
Some moved onto the locking part, both panels I have had been removed without the lock/key so I need to get the safety dome part off. The one lid was secured using cross head bolts, the other is using security bolts which you can see is ruined (hence why I imagine they were opened the way they were).
IMG_1484 by Initial D, on Flickr
So looks like I need to dremel a slot into the heads and then use a flat screwdriver to remove.
Back to Top
  Share Topic
This page was generated in 0.281 seconds.
