ukVac.com Homepage
  New Posts New Posts RSS Feed - Sega model 3 driver questions
 Post Reply Post Reply
Author
Message
Danscu View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Danscu Quote  Post ReplyReply Direct Link To This Post Topic: Sega model 3 driver questions
    Posted: 13 Sep 2017 at 4:38pm
Hi
Just putting together my disassembled Scud Race driver (many thanks again for the cab Robotech!) and have a few queries...
1)  What is this long metal piece used for normally?
2)  This ground wire has 2 connectors, I know the 2nd connector attaches to the dashboard but what does the 1st one connect to?
3)  What does this 3rd connector coming from the pedals connect to?
Thanks in advance!
Dan
Looking for:)
Electrocoin Goliath Mk 3
Sega Shootout Pool marquee
Space
Back to Top
Outrun2 View Drop Down
Avatar
Colonel Outrun
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Outrun2 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 5:01pm
1. Not familiar with the wooden base versions, sorry.
2. It will chain to the main frame that houses the monitor (not the monitor chassis, the big frame that holds it all up).
3. Nothing.
Make sure you fit the Model 3 dash (top in picture) rather than the Model 2 dash (bottom in picture).
Would like:
No more cabs.. please!!
Back to Top
Vamino View Drop Down
Avatar
3 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vamino Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 5:39pm
Pretty much what Gary said mate.
The long bar may be part of what the locking mech attaches to? I've never seen a cab with the full mech attached, all the cabs I've seen have had that locking mech removed.
Some advice from personal experience, make sure every piece of metalwork is grounded securely mate, otherwise these older Scud Race cabs can introduce some interference on the monitor/through the speakers when the FFB motor kicks in.
I look forward to seeing pics of your Scud Race twin when it's assembled! Big smile
Edited by Vamino - 13 Sep 2017 at 5:41pm
Insert Coin[s]
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Danscu Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 6:01pm
Many thanks guys thats greatSmile
Vamino - will defo get pics up once assembled, and thanks again for the lightboxThumbs Up
Looking for:)
Space
Back to Top
Fantazia2 View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fantazia2 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 7:00pm
Are the long metal pieces there to attach the metal base to that the seat slider mech is attached to.
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Danscu Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 11:37pm
Hi
Apologies in advance for all these questions but I'm a bit stuck
Thought it might be best to number the questions in this thread due to how many there areLOL
Q1 Could anyone confirm where the 3 ground connectors under the seat connect?
Q2  Just wanted to check this ground connector in the monitor section connects here?  I know the other end connects to the dash.
Q3  This ground is not connected on my other Scud cab, I assume these are only used to ground the toppers?
Q4  This ground is separate from the other wires, and I'm not sure where this is supposed to go?  Is it to ground the coin door housing?
Q5 On my other single Scud race cab, there are four wires covered by black tubing that connect to the topper (under the top panel).
On my new single cab this wiring appears missing and the wires have been cut in the past at the connector as shown.  So I assume I need to splice in new wires where they have been cut off, but could anyone confirm where they then connect to?
Many thanks!
Dan
Looking for:)
Space
Back to Top
  Share Topic
This page was generated in 0.346 seconds.
