ukVac.com Homepage
  New Posts New Posts RSS Feed - Sega View Change Buttons
 Post Reply Post Reply Page  12>
Author
Message
s18dav View Drop Down
Groupie
Groupie
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote s18dav Quote  Post ReplyReply Direct Link To This Post Topic: Sega View Change Buttons
    Posted: 07 Jan 2018 at 9:49pm
Hi
Looking for 2 x VIEW change buttons for a Sega scud racer
Not sure if Daytonas buttons fit ??? Does anyone know
Thanks guys
Cash waiting
Back to Top
corn View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote corn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 10:17pm
Pretty sure I still have one of these knocking around:
Let me know if its what you're after. £25 PPG + postage at cost.
Wanted: Crazy Taxi base artwork
Back to Top
northwest View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote northwest Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 10:19pm
Got 1 but the start button is damaged iicr ? I'll look later.
Back to Top
deano76 View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote deano76 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 5:43pm
I have this complete button panel which is correct for Scud Race and Daytona
START + 4 VIEW buttons
It's in good condition and all switches/lamps work
£40 PPG plus postage at cost
Edited by deano76 - 08 Jan 2018 at 5:44pm
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote northwest Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 10:21pm
This ?
Back to Top
Groupie
Groupie
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote s18dav Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 8:37am
Thanks for the replies guys
Here is some pics of the busted buttons
Back to Top
Groupie
Groupie
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote s18dav Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 8:38am
Back to Top
Groupie
Groupie
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote s18dav Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 8:40am
I have added a photo of the underside as well
Some of the leads I unplugged and swapped around so I could attain the
Car view I wanted
Back to Top
muddymusic View Drop Down
Moderator Group
Moderator Group
Avatar
The Repro Guy
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote muddymusic Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 9:16am
I've got a few nos button plastic covers in green. £2.50 each.
Back to Top
Bods View Drop Down
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bods Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 10:16am
Not seen them in where the Gear Shifter is before, that's quite cool
WANTED! Buggy Boy Junior Rear Seat. Continental Circus Cockpit Lower Rear Light Plexi and more space
Back to Top
Groupie
Groupie
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote s18dav Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 11:42am
Thanks ill check that the part number matches, do you know what the size is of them Muddy
Does anyone have the inner gubbins as i think the insides are shot on the
2 left hand buttons as well
Back to Top
Moderator Group
Moderator Group
Avatar
The Repro Guy
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote muddymusic Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 11:43am
They are 26 x 21mm.
Back to Top
Bods View Drop Down
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bods Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 1:22pm
There are 2 different types as well, older machines I assume it must be are spade connections on them, so wires come straight off the switch, then changed to pcb mounting them with connection from pcb
I would have a look at the back of them to see which type before buying any, 1st one doesn't look good at all, 2nd may be fine with just cover missing
Back to Top
Bods View Drop Down
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bods Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 1:43pm
few pics for reference and info
pcb and spade type
The lever moves and top comes off so you can replace top section if switch is ok and it allows bulb change
Should look like this with Bulb in and Cover missing
And without bulb like this, quite often plastic breaks so bulb holders part is loose
Sure I have some more but not sure where they are if I have, need a few spares for my machines but if I find any more I'll let you know if still no luck
Back to Top
Bods View Drop Down
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bods Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 1:45pm
These look different yours though looking at the pictures
I would get them out and have a look, take some more pics
Back to Top
Moderator Group
Moderator Group
Avatar
The Repro Guy
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote muddymusic Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 2:26pm
Yeah those look like the smaller type actually, same as used on King of Route 66 for the view and start buttons on the upright. I'll see if I've got a SCUD upright manual can look up the part number then.
Back to Top
stegrey View Drop Down
Avatar
Status: Offline
Feedback: 4.896551724137
Post Options Post Options   Thanks (0) Thanks(0)   Quote stegrey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 2:28pm
Is it a scud race dlx?
(Current cabs) sega rally twin,OR upright,Or2,Scud race upright,Ridge racer Dlx,Daytona Twin Dlx, New astro city,sega Naomi universal
Pins: TAF WCS94 Batman Forever
Back to Top
Outrun2 View Drop Down
Avatar
Colonel Outrun
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Outrun2 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 6:40pm
Yes.
Would like:
No more cabs.. please!!
Back to Top
Avatar
Colonel Outrun
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Outrun2 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 7:25pm
My guess is you'll need a red and a blue spade connector pushbutton with lamp..
509-5779-RE-CV3
509-5779-BL-CV3
I'm about to do an order with Sega so I can check availability if you like.
Wink
Would like:
Back to Top
Vamino View Drop Down
Avatar
4 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vamino Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 7:59pm
I have some but they are not for sale sorry.
Hopefully Gary can get the ones you need.
I've taken a few pics of the buttons so other people know what to look for, they are slightly smaller than the ones on standard Sega view panels. I'm not trying to wind you up, I'm just trying to help.
These were taken from a Daytona 2 Deluxe cab, which has many parts shared with the DX Scud Race cab.
Insert Coin[s]
Back to Top
  Share Topic
This page was generated in 0.266 seconds.
