ukVac.com Homepage
  New Posts New Posts RSS Feed - F3 Darksoft help needed
 Post Reply Post Reply
Author
Message
Stox58 View Drop Down
Groupie
Groupie
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stox58 Quote  Post ReplyReply Direct Link To This Post Topic: F3 Darksoft help needed
    Posted: 16 May 2018 at 3:59pm
Hi,
I'm having some trouble getting my F3 Darksoft kit working, my Motherboard is tested working ok with a cart. I'm using a 1GB SanDisk micro SD. I can scroll through the games list on the LCD and it will write to flash and it then tells me the game is loaded, but nothing is showing on the monitor, just showing like there is no cart installed on the motherboard.
Please can someone point me in the right direction.
many thanks from Luke
Back to Top
t-m View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote t-m Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 4:02pm
Have you asked on the support forum?  http://www.arcade-projects.com
Back to Top
Groupie
Groupie
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stox58 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 4:07pm
Not Yet, I've been reading some posts on there but i'm not a member of that forum yet
Back to Top
Fantazia2 View Drop Down
Avatar
Status: Online
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fantazia2 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 7:00pm
Do you not need to turn it off and on again after flashing a game?
Back to Top
penrhos View Drop Down
Status: Online
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote penrhos Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 7:40pm
As usual formatting sd cards on a Mac seems to cause problems loading games....
Mine works fine in my cab but the picture is distorted when I use it on my tv with a supergun as the F3 sync is non-standard.
Back to Top
Groupie
Groupie
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stox58 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 8:17pm
When you switch it back on the last game is still loaded in the flash, but still doesn’t load. I’m using a pc to format the card
Back to Top
  Share Topic
This page was generated in 0.984 seconds.
