ukVac.com Homepage
  New Posts New Posts RSS Feed - Kortek KTH F20 Pincushion and brightness
 Post Reply Post Reply
Author
Message
Kev A View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev A Quote  Post ReplyReply Direct Link To This Post Topic: Kortek KTH F20 Pincushion and brightness
    Posted: 11 Feb 2019 at 9:58am
Anyone got any ideas how to adjust the pincushion on one of these monitors???
its a fair bit out at the moment but I cant see anywhere to adjust it. Its also a little bit on the dim side, have replaced the Flyback but even with the screen pot all the way up it could do with being just a touch brighter, could just be an old tube I guess, so may have to live with that.
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev A Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 11:38am
Chassis looks like this....
Edited by Kev A - 11 Feb 2019 at 11:40am
Back to Top
gunblade View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (1) Thanks(1)   Quote gunblade Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 11:46am
 it does not have pincushion pot, so either you have an extremely odd fault or its on the wrong type of tube- what size tube do you have it on?
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev A Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 11:51am
19" Orion 510UDB22-TCXX, from what I can tell from the power connector in the cab it may have originally had a Hantarex chassis
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (1) Thanks(1)   Quote gunblade Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 12:44pm
have done the caps?
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev A Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 1:25pm
Not yet, I have most of the smaller ones, but need to get some of the bigger ones as there doesn't seem to be an off the shelf kit. are there any in particular that might affect cushion and brightness?
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote gunblade Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 1:28pm
could be any
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev A Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 1:36pm
Ok matey, will press ahead and get the caps changed, do you think its ok to run this chassis with this tube long term? If the caps don't fix the issues I can live with it, but don't want to damage anything.
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote gunblade Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 1:44pm
if it was an issue you would see worse problems
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev A Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 2:53pm
Ah ok that's a relief, it looks like it has been like that many years. will crack on with the cap kit and see how I get on, thanks for your advice.
Back to Top
M K L View Drop Down
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (1) Thanks(1)   Quote M K L Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 8:24pm
The Hantarex MTC900E and MTC9000 needed the pincushion board when used with this tube (there should be a label with this info on it) but the Kortek chassis doesn't have one.
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev A Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2019 at 9:51pm
Hummm I didnt see a sticker but I think at some point an op has just stuck the kortek in there the hantarex style power plug is still in the cab so im sure it had a Hantarex of some kind at some point
Back to Top
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote M K L Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2019 at 10:27am
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev A Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2019 at 10:47am
Ah I don't have a sticker, but I think I can see where it used to be, seems to be a trace of some glue, I'm sure you are right. may just have to live with it.
Back to Top
  Share Topic
This page was generated in 0.453 seconds.
