ukVac.com Homepage
  New Posts New Posts RSS Feed - Blast City monitor
Blast City monitor
 Post Reply Post Reply
Author
Message
cosine View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote cosine Quote  Post ReplyReply Direct Link To This Post Topic: Blast City monitor
    Posted: 14 Mar 2019 at 9:49pm
Hi folks,
Myself and my cabs are going to be on the road in a few months (Revivial, etc), so I figured I should get around to getting my Blast City running again.
The monitor is the MS2930 (I believe, it's the non-OSD version), and a while back it lost blue. If tap the metal frame the chassis sits on, I get flickers of blue, so I'm assuming a bad solder joint somewhere. Are there any particular areas I should be looking at for this, or just have a bloody good look at the chassis?
I'm not sure if this is worth pointing out, but it has suffered from the so-called "goop of death", which I'm led to believe is the potting compound from the linearity coil, but it's been like that since I bought it 6-ish years ago, and never had any issues until now. Embarrassed
As always, thanks for any input. Smile
Of all the things I've lost, I miss my sanity the most.
Back to Top
big10p View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote big10p Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2019 at 10:03pm
Think first thing I'd check would be the neck pins and sockets, then check through the blue circuit for a dry joint. I'm no expert, though. Smile
Oh, and check the signal connector is good.
Edited by big10p - 14 Mar 2019 at 10:07pm
WANTED: Sega Cash Cube CP end plate. Click me for details!
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote cosine Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 4:54pm
Signal connector is good as far as I can tell, will check the rest on the chassis though, once I break my back removing the monitor from the cab. Ouch
Cheers Smile
Back to Top
  Share Topic
This page was generated in 0.297 seconds.
