ukVac.com Homepage
  New Posts New Posts RSS Feed - CGA to VGA
CGA to VGA
 Post Reply Post Reply
Author
Message
Brendan1495 View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brendan1495 Quote  Post ReplyReply Direct Link To This Post Topic: CGA to VGA
    Posted: 15 Apr 2019 at 11:52am
Hi All, I am trying to set up a cab with lcd monitor and a GBS 8200 v4.00, whatever O try to do the picture is terrible and jumps all over if I try the board I am using through a supergun on the TV its great any help would be appreciated. Pictures below
Back to Top
Kev A View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev A Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 12:30pm
have you got the ground connected on the video cable, mine came loose once and something similar happened
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brendan1495 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 1:02pm
Yes the grounds connected
Back to Top
gunblade View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote gunblade Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 2:41pm
it could be clamp and clamp sp settings
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev A Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 2:42pm
holding down one of the buttons on there preforms a factory reset, might be worth giving that a go, I think I also had to play with the clamp st settings on mine, and lower them to something like 04 and 05, rather than the default which is 90 something. although that was a color issue where it would gradually get more and more pink.
Back to Top
ColinD View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote ColinD Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 2:45pm
Kung Fu Master uses an odd screen format at about 55Hz refresh rate, so might be out of range ?
Edited by ColinD - 15 Apr 2019 at 2:46pm
Back to Top
Vamino View Drop Down
Avatar
4 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vamino Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 2:55pm
I also agree with the sync being slightly out of range and some adjustment to the clamp may be needed.
I messed around with mine for hours using a 24khz input and eventually got a decentish picture out of it, which wasn't too bad considering the price of the unit. I tried messing around to get the slightly washed out colours to pop but nothing helped. There was some interferrence but doing the following eliminated the remaining noise/fuzzyness.
The unit served it's purpose until I eventually bought an OSSC which is expensive when compared to the GBS8200, but I'm very happy with the OSSC and glad I made the purchase.
Insert Coin[s]
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brendan1495 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 4:52pm
Thanks for all your help, could anyone suggest a descent LCD monitor that would support 55Hz refresh rate
Back to Top
sukhbir View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote sukhbir Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 5:38pm
Why use vga?you can pick up an old crt tv and use it’s scart rgb socket.you will hardly have any sync problems .the old TVs had generous line and field frequencies.
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brendan1495 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 6:13pm
Would do but my cab is really narrow, no room for a CRT
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brendan1495 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 8:33am
Got a CRT will try at weekend, thanks for the help
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote ColinD Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 2:32pm
I'm tempted to suggest that your board has a fault that has materialised during your swapping, the horizontal lines missing also worries me.  Have you another different game pcb to try ?
Edited by ColinD - 18 Apr 2019 at 2:32pm
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brendan1495 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 2:57pm
At the moment I dont, but if I use a supergun on the TV the picture is fine no missing artifacts, but its black and white
Back to Top
  Share Topic
This page was generated in 0.172 seconds.
