ukVac.com Homepage
Forum Home Forum Home > Trading Post > Valuations
  New Posts New Posts RSS Feed - Chihiro
Chihiro
 Post Reply Post Reply
Author
Message
Retroman839 View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Retroman839 Quote  Post ReplyReply Direct Link To This Post Topic: Chihiro
    Posted: 15 May 2019 at 6:54pm
Got this chihiro
Net dim security pic chip code reads
As house of the dead 3
But I can confirm as I cannot get anything from
The dam thing!
Any offers?
Back to Top
bbz149 View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbz149 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 8:17pm
Might be stupid question, but you do have the Video loopback cable attached?
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Retroman839 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 8:33pm
nah its a good question!
yes I did,   ,  I have heard that these have a lot of trouble cpu heat sink failing ,   basic overheating
killing the cpu,,   maybe that's the problem,  I get one little flicker on screen when firing up
red and green lights alternate constantly flashing intermittently
Back to Top
jimmerd View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimmerd Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 8:46pm
£50-75
You could send it to https://www.giz10p.co.uk/ for repair, but a lot of are non repairable.
I had a HOTD3 fail on me also.
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Retroman839 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 9:06pm
good shout ,
Back to Top
robotech View Drop Down
Avatar
3 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote robotech Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 7:41am
Arnt these pretty much scrap once the cpu fails ?
I have tryed to repair a few dead ones
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Retroman839 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 7:50am
I don’t know.
People are selling parts like
Just the bottom pcb
With the cpu
So working parts are avalible
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Retroman839 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 7:51am
Are my jumpers set correctly ?
Will I get a splash screen with no
Dim inserted?
I’m not sure my dips are set correctly
And is my link cable working ?
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimmerd Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 1:18pm
I believe that the Dimm on type 1 has some value as is is detactable, you may be able to update firmware and use it Naomi/Triforce - although I've not tried that myself.
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote robotech Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 2:28pm
Yes you can i had a working type 1 the dimm is the same as a naomi one i think mine was a 512
the ones i tryed fixing were type 3 ones without the dimm adapter top plate
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Retroman839 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 7:40pm
where is the dim located in the type 1?
Back to Top
channel27 View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote channel27 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 7:51pm
The dimm sits on top like on a Naomi.
Are you powering it up without the dimm in place?
Wanted
Tekken: 3, 5DR, 5.1, 6, 6BR, TTT2
Virtua Fighter: 2.1, 3TB, 4, 5
Any working / faulty Sega Model 1/2/3 boards
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Retroman839 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 7:52pm
do I need usb I/o  plugged in to get picture out?
don't thin this has any dims ?
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Retroman839 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 7:54pm
I was thinking simms   doh,,,
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote channel27 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 7:54pm
I get a picture on a type 3 without the usb connected
(When I swap out the game in my Crazy Taxi and forget to plug it in...)
Wanted
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Retroman839 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 7:55pm
mine has been derviced new caps and a new fan,  no discoloration  under side motherboard ,
fan spins
might be the lead ?
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote channel27 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 7:58pm
Might be anything tbh when it comes to Chihiro :S
I think they’re mainly powered by prayer
How long to you wait when you get a black screen? Sometimes mine take a while to actually get a picture onscreen. Same thing with my Naomis
Wanted
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Retroman839 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 8:06pm
True :) I will leave it while next time
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Retroman839 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 8:09pm
Even if it worked I’m still
Stuck
As can’t see me working out how to
Set up guns hotd3
And I don’t have a steering wheel
For outrun.   ????. But would be nice
To see it work,   If I don’t have an I/o
Connected will it still come on ?
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Retroman839 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 8:41pm
what jumper settings ?
jumper 8 media board switchws between netboot and gd rom , but which way?
Back to Top
  Share Topic
This page was generated in 0.297 seconds.
