ukVac.com Homepage
  New Posts New Posts RSS Feed - Outrun Repro Dash Painting
 Post Reply Post Reply
Author
Message
JAG555 View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAG555 Quote  Post ReplyReply Direct Link To This Post Topic: Outrun Repro Dash Painting
    Posted: 10 Sep 2019 at 7:09pm
Hello,
Finally got round to ordering one of Giz10p’s Outrun Repro Dash and looking forward to fitting it.
Has anyone painted one and if so do they have any tips? Paint name and type would be great.
John
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAG555 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 9:21am
Can anyone help me out or am I going it alone?
Back to Top
namfreak View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote namfreak Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 9:35am
I did my OutRun resto around 10 years ago, and at that time the repros weren't available
I had to take my damaged and cracked CP's and bezels, to a car body shop that repaired them for me (much as they would a plastic bumper)
The original Sega paint was matched as close as possible with a Spectro-photometer. I think the closest match at the time was a Renault silver that had a tinge of blue in it!
If you're handy with a spray can or gun with the colour and clear lacquer then by all means give it a go yourself.
For what it costs you might get a body shop to do it "professionally" as a hospital job at the end of the day
Remember plastics need a special primer before applying the colour coat - otherwise the colour will just crack and come off as the plastic expands / contracts and flexes
At the time I had 3 CP's and 2 bezels done which when I resold the repaired items recouped some of my outlay at the car bodyshop (sorry I don't have any left they all went years ago)
Hope that helps
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAG555 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 10:15am
Thanks for that, it is useful.
I did consider using a body shop to spray it, but to be honest the restoration costs of this cab are going through the roof (NOS monitor, new dash, new gears etc.), so I was hoping to do it myself.
I will see if I can find that colour paint.
Back to Top
Maxrom View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maxrom Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 10:40am
I have a monitor bezel and control panel that will be painted soon. Mine are going to a car bodyshop to get done. I don't have any other info at the moment, but once it's done, I should be able to let you know what paint colour and primer they used if you're still looking for details. Probably won't happen for a few weeks though. They'll be matching against the originals, so hopefully it'll look close when completed.
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAG555 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 11:02am
That would great if you could keep me posted.  Where about in Essex are you and who will you be using, as we could go into together and it might reduce the costs.
Maybe a body shop is the way to go with it!
Back to Top
nurtuo View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote nurtuo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 11:30am
I really would stick with the Professional Car Paint route, that two pack with the elasticizer is a must to stop the cracking. You will regret it otherwise after spending all that cash on the rest.
You're Cool, The Engines Hot, The Girl Is Gorgeous, A Tankful Of Gas And An Open Road......The Rest Is Up To You!
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAG555 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 12:57pm
That is probably good advice!  I have spent a bit so far and don't want to cheap out now.
Back to Top
  Share Topic
This page was generated in 0.250 seconds.
