ukVac.com Homepage
  New Posts New Posts RSS Feed - Outrun Springs Full Upright
 Post Reply Post Reply
Author
Message
sicoe View Drop Down
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote sicoe Quote  Post ReplyReply Direct Link To This Post Topic: Outrun Springs Full Upright
    Posted: 11 Sep 2019 at 8:34am
Good Morning All
i am looking for a set of Outrun Springs for my Full Upright, does anyone have a spare set laying around or know the best place to acquire a pair.
Thanks Simon
Back to Top
JAG555 View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAG555 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 9:19am
I will be selling a set of the lower tension ones with a set of the 3D Printed A & B Gears.
Let me know if you are interested.
Back to Top
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote sicoe Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 10:29am
Hi There
Many thanks for your reply.
Its just the springs im looking for as it has Giz10p Gears.
would these work well?
Regards Simon
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAG555 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 1:44pm
Hi There
Regards Simon
No, I don't think so.  I think these are the ones I have with the 3D Printed Gears.
Back to Top
nurtuo View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote nurtuo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 5:48pm
If it has the Metal Gears you will want to get some original spec Springs as the
lightened ones are only to take a bit of weight of the 3D A and B gears.
You will be glad you did it because with the original springs it really pulls the wheel
back straight quicky.
That way you can really drive it like you stole it.
Those gear will last a Lifetime. Strong springs or not.
Edited by nurtuo - 11 Sep 2019 at 5:50pm
You're Cool, The Engines Hot, The Girl Is Gorgeous, A Tankful Of Gas And An Open Road......The Rest Is Up To You!
Back to Top
stevebm1 View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevebm1 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 6:01pm
I think muddymusic picked up an outrun steering mech in a recent raid,not sure if it still had the springs intact though,you would have to ask him
====WANTED====
LATE 70'S/EARLY 80'S BALLY PINBALL PROJECT
Back to Top
muddymusic View Drop Down
Moderator Group
Moderator Group
Avatar
The Repro Guy
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote muddymusic Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 8:03pm
It didn't I'm afraid. Last place I saw original ones available new was giz10p but I think he sold out a while back.
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote nurtuo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 8:17pm
Back to Top
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote sicoe Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 12:47pm
Thanks All
ive only just seen this post i literally ordered the lightened ones an hour ago, i guess ill see how they work and if they are no good ill go for the NOS ones
Back to Top
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote sicoe Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 1:12pm
I’ve just contacted the eBay seller to see if I can cancel and will order the NOS ones
To be clear the lighter ones will work and just produce a softer drive, the NOS ones will be a more tighter heavier drive and the wheel will constantly spring back more?
Regards Simon
Back to Top
dlightbulb View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlightbulb Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 1:21pm
Regards Simon
You only really need to worry if you've installed the steel steering gears from Giz10p - otherwise the other springs will be ok
WANTED - HYPER SPORTS or Track & Field cab
Back to Top
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote sicoe Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 1:45pm
Regards Simon
Yes the cab has the steering gears from Giz10p so I’ll go for the NOS ones then and hope for a refund on the others
Back to Top
agent4125 View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote agent4125 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 4:39pm
Originally posted by nurtuo nurtuo wrote:
Hey Eddie, are those ones from arcadefixit the stronger ones for use with the metal gears?
I have a set of those ready for when I sort my upright's CP out, so hopefully they are :)
Wanted: 19" working CRT (may trade for NOS 17" polo)
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote nurtuo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 5:05pm
The Arcadefixit Springs are not just for the Metal Gears, they where used on the Original Sega Plastic
with brass core ones. I think they only use the lightened springs when you use a
3D Printed A and B Gear as these can be more fragile due to the loads.
Keep up the good work.
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote agent4125 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 5:19pm
Thumbs Up
Back to Top
  Share Topic
This page was generated in 0.250 seconds.
