ukVac.com Homepage
  New Posts New Posts RSS Feed - Circuit Board Question - Jukebox/Speaker related
 Post Reply Post Reply
Author
Message
Purity View Drop Down
Senior Members
Senior Members
Avatar
The Oracle
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Purity Quote  Post ReplyReply Direct Link To This Post Topic: Circuit Board Question - Jukebox/Speaker related
    Posted: 09 Oct 2019 at 8:01pm
Just a quick question for you tech savy guys
I have two jukeboxes - one vinyl and one cd, but I only want to use one set of speakers for both, so I thought I would wire up a speaker switcher box to switch between both units.
I was thinking about a circuit something like this (apologies for the crude drawing)
In this I was thinking of using a couple of DPST rocker switches to switch between the speakers, as below or a single DPDT toggle switch to flick between the two, but essentially the circuit would remain the same.
Would this work ok?  Can you forsee any issues?  Any better ways to do it?
Back to Top
SUPERSPRINT View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote SUPERSPRINT Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2019 at 8:07pm
Dpdt looks like the best way to do it. It isolates the input from the other pole so should cause no issues.
Edited by SUPERSPRINT - 09 Oct 2019 at 8:08pm
Back to Top
stevebm1 View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevebm1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2019 at 8:38pm
have you asked Duncan?,he's the jukebox specialist
====WANTED====
LATE 70'S/EARLY 80'S BALLY PINBALL PROJECT
Back to Top
Senior Members
Senior Members
Avatar
The Oracle
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Purity Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2019 at 10:36pm
I think this would do it with a DPDT toggle switch
No I haven't asked Duncan.  I guess it's more of a wiring/circuit question than a specific jukebox related question?
I'm sure he will pipe up if he has an opinion or view to share.
Back to Top
tin View Drop Down
Avatar
2 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote tin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2019 at 9:22am
I would just use something like this but in reverse. And remember to not have either juke powered on when the speakers are disconnected.  https://www.ebay.co.uk/itm/Radio-Shack-4-way-Speaker-Selector-Switch-Box-Control-Center-Black/293213730189
This is your crew chief // Yeah, the course is really tough // But it's a beautiful day // So good luck!
Back to Top
John Bennett View Drop Down
Avatar
4 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Bennett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2019 at 1:47pm
Would it be a problem to put another relay/switch circuit on the negative lines too?
You've got the grounds of two separate pieces of electronics joined together there - I don't know the specifics of the kit, but I'm thinking about avoiding earth loops and unwanted noise.
Edited by John Bennett - 10 Oct 2019 at 1:49pm
http://www.philwip.com -sibling 'fix-off' (I’m losing by miles).
Back to Top
Senior Members
Senior Members
Avatar
The Oracle
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Purity Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2019 at 7:20pm
yea probably not a bad idea to completely isolate the speakers from each other
Back to Top
stevelup View Drop Down
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevelup Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2019 at 8:16pm
Before you do this, put a meter between the both negative terminals on the JB and check you get zero ohms. Same on the CD.
Some amplifiers run in bridge mode and if you short the grounds together, you will destroy them. It's not common, but it's also not all that unusual either.
As long as you see a short circuit between the ground terminals, you can be sure that the amps are conventional and not bridged, then Purity's drawing is fine and you only need a single DPDT switch.
Back to Top
Senior Members
Senior Members
Avatar
The Oracle
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Purity Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2019 at 1:35pm
There does seem to be some resistance between both the CD and Vinyl grounds, when I set the meter on 200 Ohms
Vinyl Jukebox:
CD Jukebox:
Would this cause issues?
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote SUPERSPRINT Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2019 at 1:50pm
Likely, as there will be a potential difference in voltage if there is resistance. Will
the switch, switch double pole? Isolating the positive and negative? That’s what you need really.
Back to Top
Senior Members
Senior Members
Avatar
The Oracle
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Purity Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2019 at 2:24pm
I think I would need 2x DPDT switches or 1x 4PDT switch to isolate both - and + terminals.
I do have 2x DPDT switches - one (On)-On and the other On-(On).  I think if one deals with the - and one deals with the + this will work?  The only problem is I don't know when both switches are in the correct position
I may end up with the - active on the vinyl juke and the + active on the CD juke.  Although I'm not sure if this would cause issues and both are not connected at the same time
EDIT: I'm going with a 4PDT switch to isolate both jukeboxes
Edited by Purity - 13 Oct 2019 at 4:58pm
Back to Top
tin View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote tin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2019 at 12:14pm
Just get a speaker switchbox! they've got all the requisite switches inside without any dicking about.
Back to Top
Senior Members
Senior Members
Avatar
The Oracle
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Purity Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2019 at 12:53pm
True, but where's the fun in that :-)
I already had most of the parts to make a switchbox, so that's why I didn't buy one, but thanks for the link.
As far as I can tell the 4PDT will work fine.  It has 12 pins, so 4 for the output in the middle pins, and then each device on the left and right Thumbs Up
Edited by Purity - 14 Oct 2019 at 12:58pm
Back to Top
  Share Topic
This page was generated in 0.219 seconds.
