ukVac.com Homepage
Forum Home Forum Home > Arcade > General Arcade Discussion
  New Posts New Posts RSS Feed - Safely remove bubblewrap - static?
 Post Reply Post Reply Page  12>
Author
Message
BraveDave View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote BraveDave Quote  Post ReplyReply Direct Link To This Post Topic: Safely remove bubblewrap - static?
    Posted: 14 Jan 2020 at 5:04pm
I’ve got a spare game board that’s been wrapped in bubblewrap and left in a drawer for 10 years. I’ve only just been reading that it’s a bad idea to wrap pcb’s in bubblewrap because the static that can be caused could damage them. (I was a lot younger when I got it and had no idea bubblewrap would cause any problems).
Now I’m worried about it. Is there a way I can safely remove the bubblewrap as I suppose the static shocks will most likely happen when peeling away the wrap. (It’s just standard bubblewrap, not the pink static free stuff).
Back to Top
TheDaddy View Drop Down
Avatar
Status: Offline
Feedback: 4.666666666666
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheDaddy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 5:11pm
You can earth yourself using earth strap why unwraping / Handling. Nearly all the board I order are bubble wrapped and I do use it myself as its just the easy way. If its the Pink bubble wrap then it normally antistatic bubble wrap. The worse one is when they use plastic kitchen food wrap !! This is so static its unreal but ppl still use it.
Dave.
Edited by TheDaddy - 14 Jan 2020 at 5:17pm
AKA Wonderboy.
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote BraveDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 5:45pm
How would I earth myself with earth strap Dave?
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheDaddy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 8:27pm
AKA Wonderboy.
Back to Top
Monstermug View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Monstermug Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:00pm
Normal bubblewrap is probably the most dangerous during transit, where the vibration builds static.  I doubt just peeling old bubblewrap will cause much harm.  I find it's the cmos ic's that are most prone to static.  Normal ttl not so much.
Back to Top
kingtreelo View Drop Down
Status: Online
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote kingtreelo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:02pm
i've built a fair few PCs(over 200) and people always tell me this...i never have used anything like this and nothing has ever broken or gone wrong......
i think its like the myth of not putting warm/boiling water on your frozen car window because it will crack.......
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Monstermug Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:06pm
I had a dell engineer over to change a keyboard of an Alienware laptop for me.  I noticed he didnt wear a strap and was wearing a wooly jumper too, so I asked him.  His face went blue and he begged me not to say nothing to Dell as they take it very seriously.  I laughed and said his secret would be safe with me.  Got a few freebies before he left too Thumbs Up
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote BraveDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:07pm
Cheers @TheDaddy I’ve ordered one.
So is it the combination of me and the bubblewrap that creates the static then? I don’t really understand how it works. I mean I remember at school rubbing a balloon against my jumper and holding it against my hair and it would stand on end (I had hair then ).
But if I peel away the bubblewrap from the board while wearing this there will be no static created by just the bubblewrap itself?
Sorry I’m sure you know what you’re talking about I just want to be really sure myself as it’s my spare Playchoice motherboard and as you know they’re a lot more expensive than they used to be!
Edited by BraveDave - 14 Jan 2020 at 9:08pm
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Monstermug Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:09pm
Its something to do with the balance of positive and negative electrons.  Won't bore you with the science.  A bit like an arcade collector and space.  if there is space we will fill it with cabs.  When there are too many cabs we have to get rid of some.  If there is a lot of space we will fill it up really fast with a massive load of cabs at once!  and if only one space available, or not much space we tend to be selective with what we buy.
Edited by Monstermug - 14 Jan 2020 at 9:11pm
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote BraveDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:12pm
I did think about not wearing a woolly jumper at least. At this rate I’ll be unwrapping it bollock naked with myself plugged into the mains socket! If something went wrong it would take some explaining!
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (1) Thanks(1)   Quote Monstermug Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:12pm
haha, pcbs are not that fragile.
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote BraveDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:14pm
Not sure I understand the reference, but I do like the way you compare it to cab hoarding!
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Monstermug Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:17pm
I'm sure there be many here that can relate to it :D
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheDaddy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:27pm
I have built 100,s of pc's and repaired countless laptops, tv, video recorders ect ect. I always wear one , as said ttl are find but ram ect can be effected. Remember there is around 22000 volts in a carpet , low amperage obviously.
Dave.
Edited by TheDaddy - 14 Jan 2020 at 9:27pm
AKA Wonderboy.
Back to Top
big10p View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote big10p Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:30pm
I got a belt of static from a pull-over (man-made fibre) the other day like you wouldn't believe! Pinch
Back to Top
r-type View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote r-type Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:33pm
Brilliant! LOLLOLLOLLOLLOL
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheDaddy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:53pm
Oh Jesus i only just read this , can you unread and unsee something ????
Dave has left the conversation .......
Lol.
AKA Wonderboy.
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote BraveDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 10:12pm
Lol.
Does this help Dave?
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheDaddy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 10:16pm
Oh my lord no , be in therapy for years now. At least you got boxers on in the picture ! So thats a plus.
Dave.
Just a note :- image 2 you are plugged into live , image 1 you are plugged into neutral !
Edited by TheDaddy - 14 Jan 2020 at 10:21pm
AKA Wonderboy.
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote BraveDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 10:32pm
Dave.
Ah right, well at least I know which one is Earth now then
Back to Top
  Share Topic
This page was generated in 0.313 seconds.
