ukVac.com Homepage
  New Posts New Posts RSS Feed - High Voltage Silicone Sealant
 Post Reply Post Reply
Author
Message
Liam View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Liam Quote  Post ReplyReply Direct Link To This Post Topic: High Voltage Silicone Sealant
    Posted: 14 Feb 2020 at 10:41am
I had some of this before, which I think I bought from eBay, but now I can't find any for sale anywhere. Was it banned or something?
It's very handy for sealing anode cups that are inclined to discharge even after being cleaned, and I used it to seal small HV leaks elsewhere. Where can I get some now? Any help will be appreciated.
Back to Top
andyman View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote andyman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 10:50am
https://uk.farnell.com/acc-silicones/as1701-75ml/sealant-silicone-neutral-cure/dp/8497516
Initial tests indicate
       unit OK
Back to Top
ColinD View Drop Down
Avatar
Status: Online
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote ColinD Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 11:53am
I'd be more inclined to use a thin smear of HV Silicone Grease on an anode cap.
You can easily replace the cap if it's damaged and you can redo the dope around the electrode too.
Edited by ColinD - 14 Feb 2020 at 11:55am
Back to Top
Liam View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Liam Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 2:07pm
I used to have HV silicone, but I think I threw away the remainder when the tube began to leak. I thought it would be as easy to get again as it was the first time. I'm not sure if that stuff from Farnell is for HV applications.
Meanwhile, I found this on AliExpress:
Back to Top
Purity View Drop Down
Senior Members
Senior Members
Avatar
The Oracle
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Purity Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 3:28pm
I've resealed around the anode cap before with some HV varnish.  I think the recommended one is Corona Dope - think you can get it on Amazon.  I used some HV varnish off eBay
Don't know if that helps or not?
Back to Top
Liam View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Liam Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2020 at 9:15pm
Yeah, that Corona Dope looks like the thing. Thanks.
Back to Top
Retromanic2 View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Retromanic2 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2020 at 10:59am
You can get it from this site:-
They do different colours, also sell copper wire if you need to do any yoke rewinds.
Looking For a Nintendo Cocktail Metal Coin Box.
Back to Top
  Share Topic
This page was generated in 0.594 seconds.
