ukVac.com Homepage
  New Posts New Posts RSS Feed - Pandora's box 2600 jamma trips PSU
 Post Reply Post Reply
Author
Message
mx5dob View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote mx5dob Quote  Post ReplyReply Direct Link To This Post Topic: Pandora's box 2600 jamma trips PSU
    Posted: 25 Mar 2020 at 4:19pm
Hi all. Went and bought a crap pandoras box from ebay to while away the isolation hours. Prob is it keeps tripping my PSU when connected. Its got 5 volts going into it. Any idea's?
This is the version:
Cheers,
Paul
Back to Top
TheDaddy View Drop Down
Avatar
Status: Offline
Feedback: 4.666666666666
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheDaddy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2020 at 4:48pm
Could be anything - If its blowing then there is probably a short somewhere. Cheap caps !
Other boards ok on that PSU ?
Dave.
Edited by TheDaddy - 25 Mar 2020 at 4:48pm
AKA Wonderboy. If there is such a thing as reincarnation , knowing my luck , I will come back as me !!
Back to Top
Flinnster View Drop Down
Avatar
2 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flinnster Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2020 at 5:16pm
Pandoras boxes usually only use the 12v in I recall. See if the 5v and -5v pins even go anywhere with a mulletmeter.
WTD: Outrun DLX(yes REALLY!), Rolling Thunder, PacMania
Parts WTD: Any Dino King / LnB / MushiKing Spare Parts!
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote mx5dob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2020 at 9:06pm
Dave.
Everyth8ng else seems fine. One pcb i dug out if storage appears to be dead so need to check.that too
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote mx5dob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2020 at 9:13pm
Will do:)
Back to Top
SUPERSPRINT View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote SUPERSPRINT Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2020 at 9:16pm
with a mulletmeter.
Everyone needs a mulletmeter
Take the plastic box off the pcb and have a look for damage
Edited by SUPERSPRINT - 25 Mar 2020 at 9:16pm
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote mx5dob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 8:10am
with a mulletmeter.
Take the plastic box off the pcb and have a look for damageĀ
Good. Plan. Will do!
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheDaddy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 9:12am
Check PSU works with other things - If it does send the multi back !!! I would not bother messing around with it , Taking it to pieces will void guarantee and waste your time. They will send you a replacement.
Dave.
Back to Top
Robbiedog View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbiedog Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 9:19am
The auction link you shared says it's definitely 12v DC?
I didn't say it was your fault, I said I am blaming you.
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheDaddy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 9:33am
Yeh good point , It does not say what Amperage it is though so I suppose it could be blowing because of that as 12v on most PSU's that have 5 as well are 2 - 5 amps (Ish). Doubt it will be that as 100's will be using them but worth a look I suppose.
Dave.
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote mx5dob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 2:46pm
Got it to boot on my old LCD computer monitor/supergun. perhaps the screen res is too high for my cab monitor?
Back to Top
gunblade View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote gunblade Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 2:52pm
unless you have a hd crt monitor in the cab then yes- its in the spec listing
lucky you did not blow the horizontal transistor on the chassis
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheDaddy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 3:15pm
Does it not use CGA (Not as I know much about it , Just wondering ??)
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote mx5dob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 4:26pm
bloody hell. lucky escape then!
Out of interesst what would happen if that did happen? no picture at all? bad syncing?
might have to buy a used older model at some point for the cab and leave this one for the supergun
Edited by mx5dob - 26 Mar 2020 at 4:31pm
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flinnster Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 5:10pm
Some of them can be a bit of a pig to get running on 15Khz. Just because it has the jamma connector is no guarantee sadly.
Not sure what the 'solution' was. Some you held down the menu/setting button on the side while booting, others you just needed to have no connection on the VGA, others needed a new SD card image etc.. etc..
Problem is not knowing exactly what the pcb is inside (ie what was skimped on!) and what combination of hardware & software image has been spliced together by the vendor.
Edited by Flinnster - 26 Mar 2020 at 5:12pm
Back to Top
  Share Topic
This page was generated in 0.219 seconds.
