ukVac.com Homepage
  New Posts New Posts RSS Feed - K7000 Intermittent vertical collapse
 Post Reply Post Reply
Author
Message
K1ngarth3r View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote K1ngarth3r Quote  Post ReplyReply Direct Link To This Post Topic: K7000 Intermittent vertical collapse
    Posted: 25 Mar 2020 at 5:07pm
I have a Well Gardner K7000 monitor that has a few niggling issues:
Monitor has been re-capped and has had a new flyback installed in the last few months since I've owned it (The Flyback was bad when I had it but understood it worked okay for the previous owner up to that point).
Heres the issues:
1) Intermittent vertical collapse
It can be absolutely fine, and then after I switch it off and move some cables (none specifically appear to cause it) I will have vertical collapse.
2) Video jumps intermittently, I get occasional rolling screen and then other times its solid image for ages. Possibly fixed with 50/60hz pot as the image seems stable.
3) Degaussing issues, this didn't happen when the monitor was upright but since turning upside down for a light gun game its giving me some issues on the left and right sides of the screen (mostly on the right as you face from the front of the cabinet.
I think this is because the cable that goes around the monitor is very loose, repositioning this cable (or is it a degaussing harness?) makes a difference, so I guess I need a way to help it stay close to the tube whilst it's upside down...
4) There is a vertical line about 1/4 down the screen, I believe this could be a 50 60 pot adjustment to fix this one though.
Fixed with 50/60hz pot
Edited by K1ngarth3r - 25 Mar 2020 at 6:58pm
Most wanted PCBs: Ghouls N Ghosts, Splaterhouse, Rainbow Islands & Bubble Bobble
Back to Top
dieold View Drop Down
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (1) Thanks(1)   Quote dieold Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2020 at 10:22pm
I recently had a vertical collapse on my Wells Gardner K7000. I had been doing a bit of refurbishment on my cabinet and had the working monitor in and out a few times for cleaning the cabinet and also to check an old Hantarex monitor I have which was working (just) when I stored it away. When I put the K7000 back in I had vertical collapse. I searched the internet for possible causes and actually replaced the vertical IC but no difference. I checked a couple of diodes which were OK. I seemed to go round and round seeing the same suggestions. One thing I dismissed really was damage to the adjustment pots in particular the vertical ones. When I examined these with a magnifier the vertical hold pot was cracked on one of the plastic legs. I ordered a new one but actually repaired the original one by superglueing the crack together on the edges then bridging the crack with electrically conductive paint and it has been fine ever since. I should have realised that moving the monitor in and out might have caused some physical damage. So in my case it was an easy fix. Worth checking.
Back to Top
big10p View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (1) Thanks(1)   Quote big10p Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2020 at 10:33pm
If you have a remote board, check it's connected properly.
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote K1ngarth3r Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 8:24am
Thanks both, I do think it could be the remote board since when I shut the coin door it sometimes triggers it. I will reflow all the connections for the remote board on chassis and remote board itself.
Also, if anyone knows where I can order new pots from let me know, I'll order them and replace to be sure they will last.
Edited by K1ngarth3r - 26 Mar 2020 at 8:53am
Back to Top
gunblade View Drop Down
Status: Online
Feedback: 5
Post Options Post Options   Thanks (1) Thanks(1)   Quote gunblade Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 8:52am
yes sounds like a fractured vertical size pot or bad solder joint/connection to remote board
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote K1ngarth3r Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 9:38am
Thanks for all the input, it's reassuring that we're all on the same page so hopeful for a fix.
I read some places did pot kits for the remote board (In the US) but realise the chances of someone doing the same here are slim.
Does anyone know what pots would be a suitable replacement that I can order either from eBay or similar?
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote big10p Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 9:42am
If you have a manual - or can find one online - it should have a parts list in it. The resistance will probably we written on the pots somewhere, too.
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote K1ngarth3r Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 10:16am
Thanks for the prompt, I checked the manual and can see the readings, It's just finding the right size and leg placement that I'm struggling with.
The manual I referenced didn't show the remote board, but can get the pot details from here.
I thought I might as well look at the neck board whilst I'm at it too.
Edited by K1ngarth3r - 26 Mar 2020 at 10:20am
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote K1ngarth3r Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 10:46am
I had a quick search for the remote board and think these should be okay for the job.
Heres a picture of what pots are required for the remote board
Links to where to buy each:
25k (Cannot find this one yet)
Edited by K1ngarth3r - 27 Mar 2020 at 10:59am
Back to Top
  Share Topic
This page was generated in 0.500 seconds.
