ukVac.com Homepage
  New Posts New Posts RSS Feed - Operation thunderbolt pcb
 Post Reply Post Reply
Author
Message
webster007 View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote webster007 Quote  Post ReplyReply Direct Link To This Post Topic: Operation thunderbolt pcb
    Posted: 25 Mar 2020 at 10:48pm
Hi
For the corona shut down I have dug out my operation thunderbolt pcb to repair. When i first got it there was no sound. So I left it for a month, plugged it in again and it had a graphics problem. So it ended on the 'when I get the time' jobs.
Mission 1 - Repair graphics problem and restore hope
1 year later here I am.
Setup as follows
Graphic problem
I did some googling and someone had a similar problem and it was a broken/corroded address line track.
So I checked mine with an oscilloscope from source to eeprom and all looked good.
The question is what to check next?
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote webster007 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 7:25pm
I check all the address and data lines then realised that i was in the sprite graphics area. Doh
I then check the background Mask rom area and still all seems to be fine.
I popped the Mask rom out and read the chip. It did not compare with the Mame rom.
I ordered a replacement 27C400. It came this weekend.
Programmed it up and success. Tongue
Mission 2 - Get the sound working.
I am going to read all the EPROM and Mask roms first.
Back to Top
paulcan69 View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulcan69 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 5:55am
How did you read it
As what chip?
Need to look at my faulty spare pcb
And well done!!
Arcade Otaku name: paulcan69
ebay name: paulcan2
Back to Top
TheDaddy View Drop Down
Avatar
Status: Offline
Feedback: 4.666666666666
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheDaddy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 9:19am
Originally posted by paulcan69 paulcan69 wrote:
How did you read it
As what chip?
And well done!!
You need an adapter and read the banks separately as 512 using 27C4096. Then merge them to read & verify. TL866 good for this.
Dave.
Edited by TheDaddy - 20 Apr 2020 at 9:20am
AKA Wonderboy. If there is such a thing as reincarnation , knowing my luck , I will come back as me !!
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote webster007 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 12:45pm
I used a galep 4.
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulcan69 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 8:32pm
Yeah I’ve got a galep 4
How do you read em
Can you write em?
Let me know if you don’t mind
I have an op thunder to fix
And need to read and write a couple of them for sure
One has already died and someone has put a custom in there
Like an adapter and newer style repo of it
Thanks in advance
ebay name: paulcan2
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (1) Thanks(1)   Quote webster007 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 12:54pm
The sprite mask roms B67-01 to 05 are MN234000 (fujitsu I think) and can be read using a 27C400 device.
The background mask rom B67-06 is a MN234000 (fujitsu I think) and can be read using a 27C400 device.
The sound mask roms B67-07& 08 are MB834100 and can be read using 27C4096 device.
The sound EPROM B67-13 is a 27C512
The main programme EPROM B67-14,15,20 & 23 are 27C1001
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulcan69 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 5:39pm
Your a legend thank you
Took a picture of that and I can spend some time soon looking at that
Thanks to your reply
ebay name: paulcan2
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote webster007 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 4:54pm
So I read all of the mask roms and eprom and compared them to the mame roms and all looks good.
Now I get some background hum through the speaker and when I turn the volume up, it gets louder. This suggest the analogue amp is working.
Next I checked the yamaham sound chip YM2610 for serial data output, which was only a steady pulse, not much going on there. Then checked the analog out and it was just a constant 1v. So the YM2610 is not ouputing any sound. Checked the IRQ, which was constantly high.
I then moved back to the Z80, clockpulse working, RD & WR had activity but the address and data line looked very samey ie data there but not changing.
So I think it is either the Z80 or the RAM.
I am going to change the z80 first easier to get hold of instead of the Sony CXK5864BSP-10L RAM.
Back to Top
Mc-Q View Drop Down
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mc-Q Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2020 at 3:13pm
6264 ram (or 62256) should be easy to find
Back to Top
  Share Topic
This page was generated in 0.344 seconds.
