ukVac.com Homepage
Forum Home Forum Home > Trading Post > Trade Only
  New Posts New Posts RSS Feed - For Trade - 60hz pal switched md1
 Post Reply Post Reply
Author
Message
Dataeastfan View Drop Down
Status: Offline
Feedback: 4.333333333333
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dataeastfan Quote  Post ReplyReply Direct Link To This Post Topic: For Trade - 60hz pal switched md1
    Posted: 26 Mar 2020 at 3:19am
60hz switched pal Megadrive (1)
Fully Working and good condition.
Rgb scart lead.
Official pad.
(Power adapter required as I need it for famicom.)
3 Boxed/Complete games.
Streets of rage
Altered beast
Sonic the hedgehog.
Two cart only.
Wonder boy 3
Wonder boy in monster world.
Looking for a woody Atari 2600 small bundle.
Thanks.
DEF
Back to Top
badgerme View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote badgerme Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 8:53am
Did you change the crystal when you installed the switch mod so it runs at 60hz correctly?
I'm interested in doing this MOD, but unsure whether it will work with the OSSC at 1080p (5x)
Has anyone had any experience with doing this?
Looking for a burn free 29" Toshiba MS9 Tube and/or chassis
Back to Top
robotech View Drop Down
Avatar
3 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote robotech Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 10:57am
I modded an asian mega drive 1 a while ago
As it will take all cart shapes region locks without filing the cart slot
I dont remember reading anything on the guides/videos about a crystal for the 50 60hz mod
It was just wires and a switch
Same with the language mod
The 10 mhz overclock requires a crystal
But i dont really think its worth doing
Maybe i havent found the games that run better with it
Same with the language mod its not really used
A lot of the games are just in one language
The best mod by far is the csync/rgb mod
So you get your picture from the sony video chip
If you get a good quality scart lead made
To go with it the picture is amazing
All the mods are easy to do its not really worth paying extra for a modded one
The megadrive is a cheap console
But if i was doing another to keep
I would just do the 50/60 hz and the csync mod
Daytonaaaaaaaaaaaaaaaaaa lets go away
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote badgerme Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 5:14pm
Apparently from what I've read, the vertical refresh rates on a 60hz modded PAL Megadrive is a problematic as it only reaches 59.37hz, too far off spec to v-lock with most TV’s. Genuine Japanese Megadrives report a much more respectable 59.91hz. Whilst this is tolerable for many CRTs, upscalers like the OSSC will cause LCD TV's to not sync or stutter....
Just trying to decide whether to attempt the mod, or just go on the hunt for an NTSC-J Megadrive instead and keep it unmodded :P
Back to Top
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dataeastfan Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 5:44am
I didn't do the mod.
Sorry.
DEF
Back to Top
mr grissom View Drop Down
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote mr grissom Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 9:47pm
You can mod a pal one and have a crystal fitted and can switch between them to give true NTSC or PAL on a single pole.
10 mhz crystal is for speed up the system ( why you`ll only naff it in )
While i have both ntsc and pal systems it dont make a difference to me to mod them at all...
Back to Top
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dataeastfan Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 44 minutes ago at 4:16pm
Will be moving this into sales thread at £65 Inc.
Still open for a trade for or towards an Atari 2600.
DEF
Back to Top
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote mr grissom Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 38 minutes ago at 4:22pm
What about a 7800 to give you best of both worlds..
Back to Top
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dataeastfan Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 22 minutes ago at 4:38pm
Part of nostalgia wants the 2600....
If someone offered me a 7800, I'd definitely be interested though..
DEF
Back to Top
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote mr grissom Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 17 minutes ago at 4:43pm
 Dont need a megadrive i have 5 of em, but i do have an NTSC 7800 ( have a PAL one too ) that i may be be persuaded to off load.
Back to Top
  Share Topic
This page was generated in 0.125 seconds.
