ukVac.com Homepage
  New Posts New Posts RSS Feed - Help to identify monitor 'bleeding pixels' issue
 Post Reply Post Reply
Author
Message
SmoMo View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmoMo Quote  Post ReplyReply Direct Link To This Post Topic: Help to identify monitor 'bleeding pixels' issue
    Posted: 16 Sep 2020 at 10:42am
Hi,
I have a Japanese Taito Tabletop, and there is a strange smudging of pixels where it looks a bit like the colours are bleeding down the screen a bit ( although the monitor is in vertical orientation, so actually is smudging as the beam sweeps left to right on a horizontal monitor )
Does this look like the kind of artefact a cap kit would solve? Or is there some knobs I can twiddle somewhere near the neck of the tube, I can see some adjustments in there but so far I've only altered the ones near the front off the monitor ( Vertical Hold, brightness, red gain, green gain, blue gain, Vertical size, red, green, blue )
The Monitor has a Hitachi sticker on it, but I'm not sure what the chassis is.
As a bonus question, does anyone know iff there will be a Vertical Position adjustment somewhere on the chassis? At the moment I'm loosing the top part off the picture, and there is a black border at the bottom.
Ben
Edited by SmoMo - 16 Sep 2020 at 10:44am
Back to Top
Wurstkopp View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wurstkopp Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 10:51am
Have you tried degaussing it?
Robotron, Smash TV, Final Fight, Ghouls 'n Ghosts, Street Fighter 2, Donkey Kong, Galaga 88, Centipede cabaret, SNK MVS-U4, Taito MT-8
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmoMo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 10:54am
Funny you should say that, because it really needs a degauss, but this monitor doesn't have such a feature, so I think I need to order a degaussing wand right?
You can see in some of the photos that the colours are very messed up, the top right of the screen for example has greens showing as blues.
Do you think the bleeding pixels could be related to the degaussing then?
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wurstkopp Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 10:58am
Most likely. If it's till bleeding after the degauss I'd try and lower the contrast.
If the monitor doesn't have a degauss switch, it's a auto-degauss type. Maybe it's just some dry solder joints of the ptc or the ptc is broken.
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmoMo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 10:59am
Oh weird, so I just went back to look and it has a thick black rubber coated wire running around the top front of the monitor with two red leads that go do to what looks like the power supply , is that a degaussing coil of some sort?
Anyway, it is a bit loose and I moved it so it sits more on top off the monitor screen and the problem suddenly disappeared.
what does this all mean?
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmoMo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 11:06am
Ah right, so the monitor was degauss itself automatically on turn on then?
I've been trying to find a manual for the monitor/chassis but haven't been able to identify it yet, but I could put my arm into the chassis ( with the monitor turned off ) and wiggle the connector on the degauss cable a bit, then turn it back on.
I guess, if the degauss works it should make the Vrrrrrmm  noise when I turn it on like a CRT TV does ?
btw, thanks for all your help.
Also, what is a ptc?
Back to Top
Lurch666 View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lurch666 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 12:31pm
I have used an electric drill when there has been no degauss or it's a monitor I don't know how to degauss.
Just wave a running mains electric drill around the screen of the monitor (takes some practice to get it right).
You rang......?
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmoMo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 12:41pm
Thanks for the tip, I'll definitely give the electric drill a try.
So I just point the drill down at the monitor? Obviously with no drill bit in it though :)
Ben
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lurch666 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 1:09pm
Nope hold the drill side on.
You are using the spinning magnetic field of the drill to randomise the magnetic field of the monitor.
But yes-better without a bit in just in case.
You rang......?
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmoMo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 1:18pm
Thanks for the advice!
I just realised, that I can take the metal mesh off where the PCB was sat ( this is a standard 1980 Taito Tabletop ) and actually get my hand in to adjust the knob on the bottom off the monitor tube pcb.  Doesn't seem to do anything at all though which is odd.
But I did find out the the focus knob has a secret hole drilled in the tabletop directly beneath it, so I can adjust that now without having to remove the monitor.
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmoMo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 1:09pm
The monitor seems to be degaussed now, I had a massive Bang+Olufsen speaker a couple of meters away, and once I moved that the colours all sorted themselves out over the next hours or so.
But, I still have the smudging bleeding pixel problem.
It happens on all the PCBs I've tried it with.
From my limited understanding I think this could be either:
1) I'm going through a Jamma Adapter, but where the 2nd fire button for player 1 was on the Tabletop harness, it was connected to Video Ground for some reason on the Jamma side.  I had to disconnect that wire in order to get the 2nd fire button connected, but I can't seem to find where it supposed to be connected to now.  I've touched it on all the black GND wires I could find on the Table Top, touched it on the monitor metal frame. Doesn't make any difference to the picture where I put it.
2) I need to replace some caps on the chassis? The smudging looks almost like the pixels are getting stuck on, so maybe a capacitor somewhere is supposed to be discharging quickly but instead is discharging slowly?
3) It is a convergence issue, and I need to move those metal rings on the monitor tube neck in order to fix it.
If anyone could help me identify which of those 3 solutions seems the mostly likely I'd be very grateful. Or if I'm just going in the wrong direction entirely pointing me to what the solution might be.
Here's a couple more photos showing the problem ( this is Phoenix running from a MisterFPGA )
Edited by SmoMo - 17 Sep 2020 at 1:10pm
Back to Top
M K L View Drop Down
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote M K L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 2:05pm
If you can, post a grid pattern like the MVS crosshatch test or something like that.
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmoMo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 3:46pm
Is this the kind of thing?
This is the boot up screens of Bomb Jack.
Interestingly, and I have no idea why this is, on the color swatch screen the brightest Red is 5th square along, but it is supposed to be one off the darkest.
The squares that are supposed to be the brightest are dark but with a bright stripe across the bottom.
What can it all mean? :)
Back to Top
r-type View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote r-type Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 4:55pm
Is that a convergence issue?
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmoMo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 7:32pm
I don't have any expreience with monitors so I don't really know, but I was able to read a bit about convergence and it does sound possible.
I couldn't find any images to show what an incorrect convergence looks like though.
From what I could understand, there are two rings , on the monitor neck, which if moved together will move the magenta colours horizontally ( so down the screen on my monitor because it is in portrait ).
But I am wary of changing the convergence rings unnecessarily and making things worse if it isn't a convergence issue.
Back to Top
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote M K L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 8:06pm
Turn down the screen voltage and see if the horizontal distortion of vertical lines improves.
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmoMo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 8:24pm
Thanks for the idea. I tried it and the amount of bleeding remains the same, so even when the picture is nearly too dark to see I can still make out the same smudging of the pixels.
Iff I turn the brightness way up, then at some point a new kind of smearing appears, but it quite different and totally no uniform.
Do you think that the pixel smudging remaining on low brightness might point to convergence problem after all then?
Back to Top
ColinD View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote ColinD Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 7 minutes ago at 10:53am
I think that the guns are being over driven causing the bleed (brightness controls turned up too much).  Monitor might just be weak or not set up correctly and so it's been 'cranked up' to compensate and causing this issue.
Probably need recapping as it must be 30+ years old.
The bleed is a completely different issue than the colours being off (degausing).
Edited by ColinD - 23 hours 2 minutes ago at 10:58am
Back to Top
  Share Topic
This page was generated in 0.207 seconds.
