Donkey Kong rom swap. |
Post Reply ![]() |
Author | |
sukhbir ![]() User ![]() ![]() Joined: 03 Jul 2012 Location: london Status: Offline Points: 363 Feedback: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Nov 2020 at 5:49pm |
Hi all,I have a donkey Kong PCB (tk4) original and it has the us set ROMs fitted.is it possible to change these ROMs to the Japanese version ROMs? much prefer the jap version of donkey Kong where the levels go in the right order.
Lurch666 ![]() User ![]() ![]() Joined: 24 Feb 2013 Location: Stoke-on-Trent Status: Offline Points: 1312 Feedback: 5 |
As far as I know it's a straight swap of the four CPU eproms.
You rang......?
Rich ![]() User ![]() ![]() Joined: 30 Aug 2014 Location: London Status: Offline Points: 445 Feedback: 5 |
I have the high score kit by HighScoreSaves and there is an option to switch between Japan and US when starting up, I also prefer the Japan version
R
Hi all,I manage to burn the 4 cpu jap roms and 1 gx1 rom but the game does not boot?maybe I fitted them in the wrong locations?
This is the order I fitted: Romjp c_5f to c_5e Romjp 5g to c_5c Romjp 5h to c_5b Romjp c_5k to 5a Romjp v_5k to v_3p Any idea where I’m going wrong? |
According to mame that looks correct but I've seen mame not list the order correctly for the CPU roms so try revering the order: Romjp c_5f to 5a
Romjp 5g to c_5b Romjp 5h to c_5c Romjp c_5k to c_5e |
You rang......?
Hi,I will give it a go and see what happens.
TheDaddy ![]() User ![]() ![]() Joined: 25 Aug 2018 Location: uk Status: Offline Points: 2901 Feedback: 4.8 |
Same as lurch said its the 4 main CPU's - Should work. The below image is from the latest mame set :-
Hope this helps, Dave. |
AKA Wonderboy. If there is such a thing as reincarnation , knowing my luck , I will come back as me !!
hi all,swapped the roms around but still does not boot?the roms i have burned are the japan set 1 and i have done a romident and all ok?has anyone done this conversion?
Have you used exactly the same type of roms? What is the type of rom on your kong PCB?
You rang......?
SUPERSPRINT ![]() User ![]() ![]() Joined: 31 Jul 2016 Location: Devon Status: Offline Points: 2108 Feedback: 5 |
The Japanese board set TGK3 or TGK is a 4 board set. So it’s essentially completely different hardware. Are you sure this is even possible? I would doubt that a rom swap is possible due to the fact that the us and jap board sets are fundamentally different.
Amb47uk ![]() User ![]() ![]() Joined: 17 Oct 2018 Location: Loughborough Status: Offline Points: 598 Feedback: 5 |
I have a tkg4 2-board that is running jap roms currently.
I'm wanting to do the reverse of what OP wants lol. |
Hi, just to be clear I have a tkg4 2 PCB board.
It's just if your board uses 2532 eproms and you have used 2732 these eproms are not compatible.
You rang......?
I have used nos 2532 roms which I had purchased many moons ago.I did not erase the original (us set roms) in case one day I would sell my board.
That's me out of ideas then. I have never owned an original DK boardset so was just assuming it would be the same as other region rom swaps I have done with other boards. I apologise if my assumptions have steered you wrong.
You rang......?
That’s ok,your help was much appreciated.
Just found this thread about someone having problems with DK roms. Fourth post gives details of the odd mame naming. Maybe might help?
You rang......?
Hi all,good news I finally sorted the conversion problem.my board is working now with the Japanese version
![]() HTTPS://youtu.be/Qqt9rYXiEwo How fun repairing vintage electronics can be ![]() Thanks for everyone's help,much appreciated. |
Thanks for the update. i couldn't find anywhere that would actually confirm if this would work so It's nice to have it verified that this can be done.
You rang......?
Post Reply ![]() |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
